Thread: Another Climate control problem
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Another Climate control problem
    Tullamore, Ireland
    Update on my climate control problem. I ran vagcom last night, I got the following fault under controller 08 - Auto HVAC:
    00819 High Pressure Sensor (G65)
    30-10 Open of short to Plus - Intermittent.
    Can someone check the Ross Tech Wiki for me and see what it says for fault 00819 - I don't have access here in work.
    If this is related to my problem with the ECON light it would make sense because sometimes the ECON is working and sometimes it isn't. Anyone know where the High Pressure Sensor (G65) is located and what its PN is?
    Cheers.
  2. Re: Another Climate control problem
    Southern County Softy
    20 Post(s)
    From the wiki
    00819 - High Pressure Sensor (G65)
    00819 - High Pressure Sensor (G65): Open or Short to Ground
    Possible Causes
    Wiring/Connectors from/to High Pressure Sensor (G65) faulty
    Possible Solutions
    Check Wiring/Connectors from/to High Pressure Sensor (G65)
    Check High Pressure Sensor (G65)
    00819 - High Pressure Sensor (G65): Signal too Low
    Possible Symptoms
    Climate Control stuck in ECON Mode
    Possible Causes
    Insufficient Refrigerant Pressure
    Possible Solutions
    Check Refrigerant Pressure
    Check Measuring Value Blocks (MVB)
    A4 2.5 tdi QS (mapped)
  3. Re: Another Climate control problem
    Tullamore, Ireland
    Thanks Kite.
    Anyone know where the High Pressure Sensor (G65) is located?
  4. Re: Another Climate control problem
    Tullamore, Ireland
    I've found PN 8A0 820 855 AA which is described as valve/high pressure switch/safety switch in the heater section. Could this be what I need?
  5. Re: Another Climate control problem
    Tullamore, Ireland
  6. Re: Another Climate control problem
    ALDERSHOT
    Mine has just had the same problem,it will probly be the high pressure sensor, vag com will throw up g65 high pressure sensor short to ground or something along those lines, the sensoe was £38.00+vat from tps, it simply screws out without any loss of gas.
    Hope this helps
    B6 A4 Avant 1.9tdi 130 sport,full leather,armrest,ally inlays,de-chromed,sline r&r bumpers,double dinn conversion,ambient lights f&r,illuminated heater controls,black roof rails&badges
  7. Re: Another Climate control problem
    #17
    Tullamore, Ireland
    MattyBoy C, thats the fault I'm getting. Where is the sensor located? Is it in the engine bay somewhere? And can you tell me the PN of the sensor that you bought? Thanks.
  8. Re: Another Climate control problem
    #18
    ALDERSHOT
    Hi, the sensor is located in the side of the condenser just to the side of the n/s headlight, it is easier to remove the headlight then it simply screws in with a 17mm spanner, the part number is:
    8E0 959 126 C, also have a look here
    I have checked the service manual with regard to servicing G65 and it indicates that this does not interfer with the refrigerant circuit.
    the A/C Servicing notes are as follows:
    And then the Component Overview is as follows - see that Component G65 Item 7 below has the superscript "1)" against it as highlighted above.
    Use this information at your own peril thou!
    2001(51) A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE
  9. Re: Another Climate control problem
    #19
    Tullamore, Ireland
    Cheers MattyBoy!
  1. Please Help Need help with climate control demister
    By tsunami in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-11-2010, 10:25 PM
  2. 2002 a4 climate control/ demist problem
    By graham71 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-12-2009, 07:58 PM
  3. A4 B6 Aircon / climate control problem
    By aphilmor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-03-2009, 10:43 AM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
