Thread: where is the diagnostic port on
  1. where is the diagnostic port on
    Feb 2010
    Aberdeen
    A 2000 LT35?
    Had a quick look, but i must be blind
    Thanks,
    Stu
  2. Re: where is the diagnostic port on
    Pembrokeshire
    22 Post(s)
    passenger side footwell. its a round plug, not the usual 16pin obd socket, and should be pushed into the kick panel.
  3. Re: where is the diagnostic port on
    Feb 2010
    Aberdeen
    thanks, i did find it then, is there a converter, as i have the standard cable and software........I'm trying to get fault codes as the van wont rev and the glow plug light is flashing
    thanks again for the quick reply
    Stu
  4. Re: where is the diagnostic port on
    Pembrokeshire
    22 Post(s)
    no problem. im not sure about a converter. i think you may need a new lead, but im sure someone can advise.
  5. Re: where is the diagnostic port on
    There is a lead to fit the lt's diag socket on the ilexa web site (vagcom)
  6. Re: where is the diagnostic port on
    Dec 2009
    west Midlands
    I brought a VW Round plug to OBD Plug converter loom off ebay for about £12 delivered. It didnt work with my Sealey Reader though for some reason but the converter looms are out there.
  1. Latest vag com - From Ross Tech
    By Joshua in forum VCDS - General Questions
    Last Post: 26-01-2010, 11:54 PM
  2. Power to diagnostic port
    By AJC2008 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-04-2009, 10:05 AM
  3. Serial port diagnostic lead problem
    By Mr Tivoli Blue in forum VCDS - General Questions
    Last Post: 27-12-2008, 11:35 AM
  4. diagnostic port
    By vaughan84 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 25-03-2008, 06:58 PM
  5. Serial port diagnostic lead problem
    Last Post: 02-02-2008, 08:19 PM
