Thread: Will it work?
  1. Will it work?
    Aug 2009
    N.Ireland
    I was thinking of getting a vag-com with HEX-USB+CAN Interface for my 2002 passat.
    My worry is that I have changed the standard cd player for a Kenwood aftermarket one, and I have read that if you connect the vag-com to the car and have fitted another radio, there is a chance that something might blow or it just won't work because of the possible elimination of the K lines or something?
  2. Re: Will it work?
    Mansfield, UK
    You'd need to check the wiring. The problem is that many of the aftermarket radio connecting harnesses connect the amplifier out lead directly to the K-Line on the car side of the harness. Check the wiring and break this connection if you find that they are connected together, and you have nothing to worry about
  3. Re: Will it work?
    Aug 2009
    N.Ireland
    Quote Originally Posted by shark_90 View Post
    How do I identify the K line?
    I don't have any external amp fitted, so i assume if i break the connection everything on the radio will work.
    So I wont have to reconnect it after the Vag-Com work?, which means removing the radio each time I use the Vag-Com i hope.
  4. Re: Will it work?
    Ambler, PA, USA
    Please read this page - should answer all your questions:http://www.ross-tech.com/vag-com/aftermarket-radio.html
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. Towbars and electrics
    By foxyloxey in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 14-04-2008, 07:55 PM
  3. Why oh, Why wont they work!!
    By Hotrocks888 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-03-2008, 05:11 PM
  4. Help - New Stereo and Now key fob wont work
    By emma9683 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-03-2008, 07:17 AM
  5. how to work out if your car is pd
    By Abuabida in forum Bora - 1998 - 2005
    Last Post: 30-01-2008, 03:15 PM
