Thread: Thermostat housing
  1. Thermostat housing
    Feb 2010
    burton latimer
    Hi does anyone know where i can purchase a thermotat housing for my 1997 audi a6 1.8 petrol with the adr engine , hoping to not have to purchase from an audi dealer. I have been told that the thermostat is most likely stuck and that the housing will need replacing due to the fact that i have no heat from blowers and oil and temperature gauges dont go above 60 degrees . Any advice mst welcom
  2. Re: Thermostat housing
    Jan 2009
    towcester northants
    you dont need to replace the housing unless its leaking or damaged
    i would check the water pump circulation as well
  3. Re: Thermostat housing
    Feb 2010
    burton latimer
    thanks for the advice will do a thorough coolant flush , and i already have brought a thermostat so may as well replace the water pump as well , could this be why i amonly getting about 50 miles from a tenners worth of peterol ??
  4. Re: Thermostat housing
    Jan 2009
    towcester northants
    if car runs too cold it will affect fuel consumption
  1. cracked thermostat housing!
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 15-05-2008, 06:34 PM
  2. where is my thermostat housing?
    By lolly in forum Golf MK3 - 1993 - 1999
    Last Post: 05-04-2008, 10:09 AM
  3. Golf Mk IV Engine temperature dropped
    By mangoman in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2008, 11:11 AM
  4. '97 R reg Polo 1.4CL Thermostat housing
    By Tony66 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-11-2007, 10:08 PM
  5. Replies: 7
    Last Post: 14-11-2007, 11:49 PM
