Thread: Fan trouble.
  1. Fan trouble.
    May 2007
    Hi all.
    Iv got a 98 Passat Tdi. There is the viscous fan and an electric fan on the front. The electric fan which i assume is the aircon fan never runs. With or without aircon on. The climate control often flashes a fault which shows up as the triple pressure switch. Is this the trouble with my fan or something different?
    Oct 2005
    Lutterworth
    The electric fan should run all the time the climate is on.
    If it is not running then the most likely problem is with the fan itself.
    Test by reading its motor resistance from the connector panel near the PS reservoir. The connector with the two thickest wires is the one you want.
    If that is ok then the next most likely candidate is the resistor plate that controls the speed of the fan. Test by disconnecting the radiator thermal switch, lower ns of the rad, and short each pair of wires in turn, 1-4 and 2-3. One pair runs the fan at full speed and the other runs at slow speed. If it only does full speed then the r-plate is duff.
    The fuses for the fan are under the dash, above the driver's feet, and almost inaccessible :-(
    You need to drop the lower dash off to see them: two screws on the end near the main fuse panel and two hidden in the cubby holes.
    As I recall there is a 5 amp fuse for the relays and 40 amp for the fan itself.
    You can tell I have just had problems with mine can't you
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    May 2007
    Ill have a look at that tomorrow thanks mate. Iv had this car about 2 years and its never worked. Im trying to sort out the nigely faults it has.
    May 2007
    Looks like its my fan. Iv got power to the fan but its not turning. wheres the cheapest place to get one??
    Oct 2005
    Lutterworth
    Try GSF or Eurocarparts.
    Passat 1.8SE 1998
  1. gti trouble!!!!!!!!!
    By wadi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-05-2007, 12:00 PM
  2. coupe trouble
    By greg richardson in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-04-2007, 03:56 PM
  3. B6 oil light trouble!
    By jjt5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-02-2007, 02:14 PM
  4. Turbo trouble ???
    By geordie in forum Archive posts
    Last Post: 18-02-2007, 03:33 PM
  5. MK3 Golf GTI trouble
    By svenandnancy in forum Chat - Completely Off Topic
    Last Post: 18-05-2006, 07:57 PM
