Thread: front hub nut - left or right hand thread?
  1. front hub nut - left or right hand thread?
    Jan 2010
    Berwick UK
    Passat 1.9 TDI 2001 Estate - front Wheel Hub Nuts - lh or rh thread? Having discovered split CV boots, I'm about to jack car up to get shaft off. I need to loosen the hub nuts first and they are very tight - can I assume they are normal right hand threads on each side and use superhuman brute strength in a normal anti-clockwise direction? They feel like they will break - does this happen sometimes?
  2. Re: front hub nut - left or right hand thread?
    Jan 2009
    towcester northants
    normal thread just tight
    if your changing the cv boots pull back the abs sensors before removing the cv joint as you can damage them on refitting then push back into posistion afterwards
  3. Re: front hub nut - left or right hand thread?
    Jan 2010
    Berwick UK
    Thanks for your quick reply towcestervag - and for the warning about the speed sensors.
    Now where did I put that scaffolding bar?
  4. Re: front hub nut - left or right hand thread?
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by trevtherev View Post
    I think you left it in here somewhere..
    Nothing to see here, move along..
  5. Re: front hub nut - left or right hand thread?
    Jan 2010
    Berwick UK
    Quote Originally Posted by towcestervag View Post
    Both the nuts came slack OK, but were worryingly tight. The problem now is moving the speed sensors - I've asked about that in a new thread.
  1. Hub Nut
    By jonathanfenton in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2009, 07:20 PM
  2. 1998 A4 Airbag Controller - need recode number
    By jhutchison in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-09-2008, 05:32 PM
  3. Greener New Generation Audi A3 Range Majors On Efficiency
    Last Post: 10-05-2008, 01:37 PM
  4. How to undo Passat front HUB bolt ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-08-2007, 10:32 PM
