Thread: 1.8t throttle problem
  1. 1.8t throttle problem HELP PLEASE
    Jan 2010
    crewe
    My 1998 audi a4 1.8 turbo has a throttle problem.
    A friend of mine diagnosed the car and the fault codes 17967 and 01165 came up.
    I replaced the throttle body and sensor located on the inlet manifold but i still have the same problem.
    It starts, but wont rev past 1500 rpm. It revs up to 1500 rpm then drops to about 700rpm and then back to about 1000 rpm idle.
    Any ideas?
    I have tried disconnecting the battery, touching the 2 terminals to reset the codes but it still has the same problem.
    I should mention the radiator isnt fitted at the moment. Would that make a difference?
    Obviously i dont leave the car running....i am just trying to get it revving properly(not warming it up)
  2. Re: 1.8t throttle problem
    Jan 2010
    crewe
    what do i have to do to get a reply around here? this is my second thread with no reply....
  3. Re: 1.8t throttle problem
    May 2009
    rhodesia, nottinghamshire
    Hi Mate,
    Dont think their ignoring you, prob no one has got any info for you..
    I have just had a look on autodata and 17967 say's Throttle control unit-basic setting malfunction.: accelerator or starter motor operated during basic setting.
    01165-idle speed control(ISC)actuator/throttle motor: basic setting not carried out..
  4. Re: 1.8t throttle problem
    Jan 2010
    crewe
    ok, i changed the throttle body and let the throttle position thing set itself up without presing the accelerator.
    It will rev to 1500rpm then either die or down to about 500rpm then back up to 1500rpm but you can guarantee within a few seconds it will cut out
  5. Re: 1.8t throttle problem
    chrismaher2007 Guest
    when i got that fault it was a split in the crankcase breather pipe.
    same symptoms as yourself but on an a4 b5 1.6se ARM type engine
  1. Throttle Problem?
    By steve982 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 28-11-2009, 09:50 PM
  2. 2004 1.8t air problem
    By mark_julian in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-11-2009, 09:52 PM
  3. Replies: 6
    Last Post: 20-02-2008, 09:35 PM
  4. Beetle 1.8T throttle problem?
    By premsparky in forum Archive posts
    Last Post: 09-02-2008, 01:16 PM
  5. a4 1.8t 96 starting problem Help please
    By chrissgoduk1985 in forum Archive posts
    Last Post: 14-06-2007, 09:35 PM
