Thread: Engine Management Light on and Temp Gauge reads low
  1. Engine Management Light on and Temp Gauge reads low
    Aug 2007
    Cumbria
    Hope someone can help!
    Just driving home and the engine management light came on and I noticed that the temperature gauge is reading minimum. Seems to drive OK. I tried too ring my garage but just missed them.
    Any ideas? Temperature sensor maybe?
    Will I be OK driving it to the local garage tomorrow am? Don't want to do any damage!
    Thanks for any advice
    53 1.9 TDi 130 SE [6] Avant Ocean Blue
  2. Re: Engine Management Light on and Temp Gauge reads low
    Aug 2007
    Cumbria
    Any ideas anyone? My garage says it sounds like a coolant sensor but they were flooded recently and they are closed.. Thanks
  3. Re: Engine Management Light on and Temp Gauge reads low
    Southern County Softy
    20 Post(s)
    Sounds like the temp. sensor,its cheaper to change than the thermostat so a good place to start.
    A4 2.5 tdi QS (mapped)
  4. Re: Engine Management Light on and Temp Gauge reads low
    Aug 2007
    Cumbria
    Thanks! Doesn't sound like a major problem thank goodness
  5. Re: Engine Management Light on and Temp Gauge reads low
    Jun 2008
    Beverley, east Yorkshire
    sounds exactly like a coolant sensor as it sends info to the ecu aswell as the guage. so if it suddenly failed then the ecu is telling you there is something wrong using the engine management light.
    A4 AVANT 2.5TDI SPORT QUATTRO
  6. Re: Engine Management Light on and Temp Gauge reads low
    Aug 2007
    Cumbria
    Thanks. That makes sense! Will try and find somewhere local to get it sorted. Don't want to pay main dealer prices if I can avoid it!
  7. Re: Engine Management Light on and Temp Gauge reads low
    Jan 2009
    Moray NE Scotland
    Had my sensor changed recently after giving same symptoms on my 2.5 TDi quattro. It cost £55 all in (part, labour and VAT) at my indy. Think it was 30 mins labour.
    Regards
    TAF
