Thread: Audi A4 2.0Tdi BLB wheel bearing housing right
Results 1 to 10 of 11
  1. Audi A4 2.0Tdi BLB wheel bearing housing right
    Finland
    Does anybody know that what is the partnumber for wheel bearing housing (right)?
    Car is Audi A4 2.0Tdi BLB 2005 fwd 6-speed manual
    Thanks!
  2. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    134 Post(s)
    2007 Post(s)
    What is the cars VIN number?
  3. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    Finland
    Vin number is WAUZZZ8E45A527118
  4. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    134 Post(s)
    2007 Post(s)
    Bump this thread later so I see it at home and I will work it out for you.
  5. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    Finland
    Ok, thanks!
    Will wheel bearing/housing what is from car whit vin WAUZZZ8EX5A452506 fit to my car?
  6. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    134 Post(s)
    2007 Post(s)
    Your car is awkward as “no ‘fi’ function possible” is stated on the system for your car in relation to the wheel bearing housing. You have to see what your housing is marked as.
    If it is
    8E0 407 242 H
    8E0 407 242 K
    8E0 407 242 C
    8E0 407 242 E
    8E0 407 242 H
    Then the new part is 8E0 407 254 F which then went to 8E0 407 254 E
    If it is marked
    8E0 407 242 G
    8E0 407 242 J
    8E0 407 242 F
    8E0 407 242 D
    8E0 407 242 B
    Which is also 8E0 407 254 E
    So that makes it rather confusing and it is the same situation with the second VIN you quote.
    You need to know the number cast into your housing and the one from the donor car, for a new part it is pretty easy in being 8E0 407 254 E but for used parts I think the used part needs to fall into the same group as on your car as listed above.
  7. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    Finland
    Thanks!
    So is there some difference between 8E0407254C and 8E0 407 254 E
  8. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    134 Post(s)
    2007 Post(s)
    8E0 407 254 E replaces all other numbers, it is quite confusing but if you want to buy a used part, as far as I can tell it must fall into a matching group of numbers.
  9. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    Finland
    Thanks for help! I try now search proper used part.
  10. Re: Audi A4 2.0Tdi BLB wheel bearing housing right
    Finland
    I found a suitable wheel bearing housing. What kind of job it is to change?
  1. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  2. World Debut For The All New Audi A3 Cabriolet
  3. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
  4. The performance SUV Audi Q7
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
