Thread: stud pattern pcd
Results 1 to 10 of 14
  1. Question stud pattern pcd
    Apr 2007
    Suffolk
    Is the pcd 5 x 112 on a 96 a4 b5?
    Oct 2005
    It is.
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    I can confirm Audi A4 is a 5 x 112 stud pattern after buying a set of A4 alloys for my 5 x 100 fabia! DOH!
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    norn iron
    a4,a6,a8 and i think passat and if im not mistaken ford galaxy are all interchangable,unfortunatly golf and audi tt rims wont fit,i made the mistake of gettin me hands on a mint set of tt rims a couple of years ago. i thought they would have went straight on but how wrong was i flippin rageing i was, cause they would have looked well.that was before i was introduced to this site ofcourse
  5. Question
    Apr 2007
    Suffolk
    Cheers for the info.
    Hofele design do 9 x 20 inch alloy, 5 x 112 with a 40 offset.
    Do you think they will fit with a -40mm suspension drop?
    norn iron
    Quote Originally Posted by littlejim View Post
    20they may well fit the rear but the front im not sure.dont quote me, but they will be well tight y go that big it will drive like 4x4 19s r bad enough
    Apr 2007
    Suffolk
    I sent hofele an e mail to see if they will make a 18 or 19 of the same wheel, I should find out in a couple days (hopefully).
  8. Question
    Apr 2007
    Suffolk
    They said they haven't fitted them to a b5 before, but they have fitted a set on the b6 with a 5mm spacer so should fit in theory?
    Is there any difference in the suspension or arch space?
    Apr 2007
    Nottinghamshire
    I'd be worried that your car will sit far too high - also i read something a while ago that said you should always get a type of wheel which was designed in or around the period your car was made - personally i think 20's would stand out too much - i'd keep to 17/18 (tyres will be cheaper too!)
    Chris555 – Audi A4 B5 – One of the UK’s Lowest Audi’s
    Audi A4 B5 1997 1.8cc Lowered 120F/100R on Coilovers - "bring on the corners!"
    Aug 2006
    Arnt the latet TT's 5 x 112 ?
  1. Headlight beam deflectors/masks: original pattern
    By PopDorset in forum Touran - Sharan - Caravelle
    Last Post: 23-08-2007, 10:58 PM
  2. wheel stud pcd?????
    By tut_gareth in forum 80 - 90
    Last Post: 08-06-2007, 08:28 PM
  3. engine been stud
    By e6m6a6 in forum Polo - Derby - Lupo - Fox
    Last Post: 08-05-2007, 11:28 PM
  4. Wheel stud thread
    By coxy in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2007, 05:36 PM
  5. bolt pattern
    By stuvette in forum Chat - Completely Off Topic
    Last Post: 05-06-2006, 09:30 AM
