Thread: Passat 2.0tdi sport 140
Results 1 to 8 of 8
  1. Passat 2.0tdi sport 140
    Feb 2010
    gwynedd
    My car seems to suffer from black smoke during acceleration. It has been back to the dealers twice, can tfind anyhting wrong. From my limited knowledge of engine management systems surely we should not be getting too much black smoke duaring acceleration. Has anyone got a 2.0 tdi 140 that doesnt smoke on acceleration?
  2. Re: Passat 2.0tdi sport 140
    Feb 2009
    Erskine
    How do you drive your car? If you drive it easy then accelerate there will be a build up of suit being released. Think this is worse on DPF models.
  3. Re: Passat 2.0tdi sport 140
    Scunthorpe
    I read, somewhere, that the 170 does indeed smoke more than the 140 due to mapping and greater power.
    Does your car get good, long, occasional runs? Does the DPF run properly? What fuel do you use and have you tried other sources?
  4. Re: Passat 2.0tdi sport 140
    Apr 2007
    France
    12 Post(s)
    I thought the idea of a DPF was to stop black smoke.
    1996 Laguna 2.2D
    1977 MGB roadster
  5. Re: Passat 2.0tdi sport 140
    As far as I'm aware, my '56 Sport 170 (with DPF) never smokes. As Quatrelle says, the DFP is specifically to remove diesel particulates.
    Mike
  6. Re: Passat 2.0tdi sport 140
    Feb 2010
    gwynedd
    Quote Originally Posted by kennym999 View Post
    I use my car for work, regardless of how i drive the smoke issue remains. Last week I accelertaed hard from third gear to sixth gear but the problem remains
  7. Re: Passat 2.0tdi sport 140
    Feb 2010
    gwynedd
    Quote Originally Posted by james_tiger_woo View Post
    I use fuel from shell garages most of the time.
  8. Re: Passat 2.0tdi sport 140
    Mar 2007
    Warrington. UK
    I also found that the black smoke from my 2.0 Tdi made far less smoke when I used Shell diesel. I then consistently used Shell and the smoke problem disappeared, until I was running low in the tank and had to use Morrisons diesel. The black smoke re-appeared under moderately hard acceleration.
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Difference between GT140 & SPORT 140
    By carlsbergy in forum Golf MK5 - 2004 - 2009
    Last Post: 13-02-2010, 07:39 AM
  3. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  4. passat b5.5 sport Gone
    By FLIPKEY in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-04-2008, 11:52 AM
  5. What company car should I choose and what is my Touran Sport worth?
    By Matt B in forum Chat - Completely Off Topic
    Last Post: 20-01-2008, 07:32 PM
