Thread: Clutch pedal needing adjusted or Clutch on way out?
Results 1 to 10 of 15
  1. Clutch pedal needing adjusted or Clutch on way out?
    Feb 2010
    Lanark, Scotland
    Hi this is my first post.
    Now i don't know if i'm being paranoid or not as i had to get the DMF & clutch replaced under warranty on my last car (vectra cdti 150) after 40,000 miles and the car was only 2 & a half years old.
    Anyway since December i've noticed i have to let the clutch pedal out further to catch the biting point. At first i'd say the pedal had to be let out about half way before biting point was found now the pedal feels as if it's 3/4 of the way out before the biting point is found.
    My Passats an 07 plate 4motion with 24,500 miles on the clock.
    Also am i right in thinking that although all VW cars come with a 2 year manufacturers warranty as i bought the car second hand from a VW dealership its covered for another 2 years after the balance of the manufacturers warranty has expired?
    I'm going to book the car into the dealers this week to see what they reckon.
    On my vectra you could hear the DMF rattle when the clutch pedal was pressed half way down to the floor my Passat isn't doing this either the only problem is with the clutch pedal i've also found the gear box to be "notchy" in the cold weather but just put it down to the extremely cold weather that we'd had.
    Anybody got any ideas or opinions?
  2. Re: Clutch pedal needing adjusted or Clutch on way out?
    Mar 2009
    staffs
    hi ross
    your cars main warranty will run out this year.then it will have the remainder of vw all component warranty left on it (what month did you buy the car)?,if you read through it im sure it states clutches are not covered but if i was you get it done/looked at while you have the remainder of the main warranty left.as for your gear changes been notchy 1st thing im sure its normal,my old 2001 passat done it,as does my 06 jetta does now.
  3. Re: Clutch pedal needing adjusted or Clutch on way out?
    Feb 2010
    Lanark, Scotland
    The cars 3 years old in May surely it be needing a clutch after only 24500 miles!
  4. Re: Clutch pedal needing adjusted or Clutch on way out?
    131 Post(s)
    1973 Post(s)
    It is self adjusting, no manual adjustment is possible and yes, they are rubbish and I have seen them fail in 5K miles.
  5. Re: Clutch pedal needing adjusted or Clutch on way out?
    Feb 2010
    Lanark, Scotland
    If the warranty doesn't cover the clutch how much am i looking at?
  6. Re: Clutch pedal needing adjusted or Clutch on way out?
    131 Post(s)
    1973 Post(s)
    For genuine parts and dealer labour with a DMF and clutch, I would say about Ł1500.
  7. Re: Clutch pedal needing adjusted or Clutch on way out?
    Quote Originally Posted by rossvwp4m View Post
    After the two year manufacturer's warranty you should be covered by a dealer's warranty for another year, or 60,000 miles, so for you the mileage is irrelevant.
    Normal wear and tear on a clutch won't be covered, but if it's due to a manufacturing defect then it should be, and I think the DMF may fall into the latter category.
    However, although dealers seem to bend over backwards to do work under the manufacturer's warranty - because they make money out of such work - they may be less enthusiastic under the dealer warranty, because it costs them money, so be prepared for them being more likely to try to blame it on you rather than a manufacturing defect.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  8. Re: Clutch pedal needing adjusted or Clutch on way out?
    Feb 2010
    Lanark, Scotland
    I'll just need to hope i'm being paranoid about the clutch. Fingers crossed.
  9. Re: Clutch pedal needing adjusted or Clutch on way out?
    Feb 2010
    Lanark, Scotland
    Had a second opinion from the father in law - he's had VW's all his days he says the clutch feels fine. He said it feels the same as the clutch on his 58 plate Golf 2.0TDI.
  10. Re: Clutch pedal needing adjusted or Clutch on way out?
    Feb 2010
    Lanark, Scotland
    Just to update this.
    I had the car in for a service this morning & told the dealership that i'm getting a shudder from the clutch 1st thing in the morning when the cars cold after sitting all night. It only happens when i reverse out the drive & put the car into 1st & let the clutch out (although it also did it the other morning when i pulled away from the shop after getting my papers on my way to work).
    The garage said they couldn't find anything obvious wrong but they'd like the car in for a couple of days to strip the gearbox out to check the flywheel as my warranty expires in June this year. They're going to phone me on monday to arrange when they can supply me with a courtesy car so they can look into it.
    Is this normal service or do they suspect what i suspect?
  1. VW Golf TDI MK3 clutch pedal weld broke
    By typolee in forum Golf MK3 - 1993 - 1999
    Last Post: 09-07-2009, 10:09 AM
  2. Clutch Pedal Judder
    By macker6464 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2009, 10:45 PM
  3. clutch pedal problem
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-08-2008, 09:04 PM
  4. 2005 A3 1.9TDi - PLAY ON TOPOF CLUTCH PEDAL!
    By shairaz1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-02-2008, 08:17 PM
  5. Shafted....really?
    By Martin Burnard in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:44 PM
