Thread: touran
  1. touran
    Jan 2010
    gloster
    can anyone help me my touran has water in nearside rear foot well car stinks of mould and damp smell please help
  2. Re: touran
    Dec 2019
    Bolton UK
    Quote Originally Posted by 33flat4 View Post
    Hello, I have the same problem - did you ever find the problem and a solution?
    many thanks, Neil
  3. Re: touran
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Do you have a sunroof?
    If you have the underfoot hatches you can remove plastic then cut out carpet with a Stanley knife to help with mopping up. Plastic will then hide cut line and make things look tidy.
  4. Re: touran
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    I have water on driver's side at the moment. Not sure if is rain leaking in, or hole in line to rear window washer (which is on right I think). I do have to hold the stalk for a while, as though the pipe is being refilled...
    After doing the cut out trick and sponging out about 4 pints of water I've pulled the bungs that are exposed and parked with slope to rear to hopefully let more water free itself and trickle out.
  5. Re: touran
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Couldn't see more water settling as wiper was pulled, but did seem to be some after last night's rain. Decided to check the windscreen / plenum drains. Not as clear as they should be, so scooped, rinsed and agitated until they were. These are the two holes at far left / right of the black trim under wipers. They drain into a "pocket" that you can see when bonnet is lifted, and those pockets have a ~10mm hole to drain to wheel arches.
  1. Match model brings added spark to volkswagen touran range
    Last Post: 21-02-2010, 12:55 PM
  2. Match model brings added spark to volkswagen touran range
    Last Post: 01-08-2009, 04:20 PM
  3. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
  4. FIRST PICTURES OF NEW TOURAN REVEALED BEFORE PARIS SHOW
    Last Post: 13-09-2006, 07:14 PM
  5. Touran enhancements mean a greater deal!
    Last Post: 29-11-2004, 08:40 PM
