Thread: 2.5 TDI Taking longer to start.
  1. 2.5 TDI Taking longer to start.
    Hello, My car is an Avant 2.5 TDI (2005), it was always quite good at starting, even when very cold, A couple of weeks ago it seemed to take a while to start, now it seems to be getting worse. When it is cold I have to wind it over for quite a while untill it fires up, when it is going it is all ok. When it is warm it starts better but not as is was. Ant ideas?
    Cheers Pete.
  2. Re: 2.5 TDI Taking longer to start.
    Aug 2008
    West Yorkshire
    is it slow cranking over? if so could be your battery as the last cold spell we have just had has nailed quiet a few batterys, if it turns quiet well could be worn glow plugs, get a battery check most garages test for free.
  3. Re: 2.5 TDI Taking longer to start.
    The battery is fine, the engine turns over as good as ever.
    When the engine is warm it will restart well but only if you restart it quite quickly, if it is left for say 10 minuites the glow plug light will go out after a short time (same as always) but then you have to hold the starter on for longer again. Cheers Pete.
  4. Re: 2.5 TDI Taking longer to start.
    Mar 2009
    hi, same prob with my 2.0 Tdi saloon (55). what ive noticed is after the glow plug light goes off i have to wait for the air bag light to go off then it sems to start.. i dont know if im mistaken though.
    i used to have a similar prob on my 1.8T petrol (b7) and it was the starter motor so could possibly be that
  5. Re: 2.5 TDI Taking longer to start.
    Jun 2016
    Surbiton UK
    @S_Line
    Did you change the starter motor yourself? If so how did you find it. I m trying to change mine in my A4 B7 Estate and really struggling with access to some of the bolts!
    Rob
  6. Re: 2.5 TDI Taking longer to start.
    Jul 2007
    glasgow
    35 Post(s)
    change glow plugs
    starter needs to turn over 280 rpm or fuel might not flow, might seem ok if its getting slower over a period of time ..........................
    Coolant Temp sender unit another favourite to go
  1. HELP!! please!! a4 2.5 tdi wont start
    By stevo0582 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-02-2008, 02:10 PM
  2. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  3. A6 2.5 TDI Pierburg Maf????
    By FuNkYcHiCkEn in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-06-2007, 06:28 PM
  4. A6 2.5 TDI Pierburg Maf????
    Last Post: 25-05-2007, 05:57 PM
  5. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
