Thread: Leaking sump plug - threads gone. Helicoil or replace sump? With picture.
  1. Leaking sump plug - threads gone. Helicoil or replace sump? With picture.
    Mar 2009
    Hi all, just thought I would share a recent 'experience' of a common problem, and what we found out from it.
    While changing the oil on a 110 tdi toledo, the sump plug was put back in before the engine re-filled with oil. All seemed ok, except for a small weep of oil from around the sump plug. A small tweak of the spanner later and the sump plug went loose in the hole. The car was driven for a few hundred miles, and the weeping oil continued but was no worse while a plan was devised.
    Options were: bodge it with tape/sealer/different washer, helicoil the sump (in situ or removed), drill an oversize sump hole, or replace the sump. I read the various threads and opinions on the matter, spoke to some local garages and technicians, and decided to replace the sump.
    Having drained the (less than 500 miles old) oil out, and then taken the sump off, it was clearly the right choice as there were lots of large pieces of swarf in the sump (one circled in red). I dread to think how much of this would have been left in the engine if the sump was not taken off, or if it was helicoiled with the sump still in situ.
    2 0 0
  2. Re: Leaking sump plug - threads gone. Helicoil or replace sump? With picture.
    Pembrokeshire
    22 Post(s)
    theres a right way to do things, theres cheap ways and there are bodges. well done for choosing the right way. just be careful not to overtighten that new drain plug.
  3. Re: Leaking sump plug - threads gone. Helicoil or replace sump? With picture.
    Oct 2010
    Southampton, England
    Recently had exactly the same problem when my Toledo went in for a service, got phoned that the sump plug thread had come out with the plug....i chose the new sump route as well, better safe than sorry!
    Avant Drivers Club
  1. Question sump plug
    By williamjack in forum Bora - 1998 - 2005
    Last Post: 05-10-2009, 07:01 AM
  2. Please Help Oil Leak from Sump Gasket
    By freestuffinnit in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-08-2009, 01:14 PM
  3. Sump Bolts and oil leaks......
    By bigchris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-08-2009, 01:02 PM
  4. Sump plug washer
    By Dunk in forum The Commercial Range
    Last Post: 25-07-2009, 11:18 AM
  5. oil sump leak
    By k9max in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-05-2008, 07:08 PM
