Thread: replacing dash panel
  1. replacing dash panel
    Is a new dash panel/speedo rev counter unit plug and go?
    Is the milage stored in the ECU?
  2. Re: replacing dash panel
    Oct 2009
    Ohio
    Usually swapping in a different cluster is not plug and play. Depending on the year of the car, the Immobilizer needs to be readapted and the mileage changed on the cluster. Unfortunately not as simple as removing the old one and installing the new one. If the Immobiliser doesn't match up, the car will not run.
  3. Re: replacing dash panel
    Quote Originally Posted by ECS Tuning View Post
    Thanks. Are you rely in OHIO?
    Car is 2003 Mk 4 TDI
  4. Re: replacing dash panel
    Jan 2008
    Mansfield, UK
    It is possible to swap them but it's a specialist job. We can do them but I am unsure of your location.
  1. How To DIS AND CRUISE RETRO FIT b6+b7
    By a8 tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2014, 09:43 AM
  2. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  3. dash - LCD panel Replace?
    By passing in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-05-2009, 05:24 PM
