Thread: battery tray drain plug.......
  1. battery tray drain plug.......
    Mar 2007
    Sunderland
    hi guys,about to remove the battery and clean out the drain hole under the tray and wondered if i will need to put the radio code back in once battery is connected again... many thanks
    Apr 2007
    Hampshire
    In short, yes you will!
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
    Oct 2005
    I'd have it to hand just to be sure.
    I personally have never needed to enter the code again when disconnecting the battery. But YMMV
    Mar 2007
    It all depends on the type of radio. Mine is a Sony with removable panel and there is no code to lose/replace. BTW, I nearly creased myself getting the battery out/in - its not ideally placed for this operation and then a couple of weeks later the battery went kaput and the process had to be repeated! I saw a tip on another thread that I will try next time and that is to get your hand under the scuttle and poke a finger through the drain hole without moving the battery. This might solve a short term problem but it doesn't of course prevent the surrounding debris from clogging it up again.
    Warrington, Cheshire
    My eight year old A4 has just suffered from the blocked drain plugs - - still drying out the carpets! It happened while away on holiday so I had limited tools etc. However, I did have Jumper leads and immediately after removing the battery, and putting it on the ground, I reconnected it using the jump leads onto the cables (suitably insulated with electrical tape!). I had replaced the battery about a year ago and found the radio did not lose the code so I guessed that if the radio was without power for only a short period of time it didn't lose the code. That proved to be the case.
    I found a very good article on the problem from a VW Passat owner (complete with pictures etc that helped me tremendously) - see http://www.weirdlittlebiscuit.com/passat/leak/index.htm
    Mike
    Canada
    The radio code is tied to the ecu, so if you put the radio back into the same car then you will not need it.
    When i had my bluetooth kit installed the installer passed on this info, when i ask him would he need the code.
    Rob
    Quote Originally Posted by onzarob View Post
    Rob
    Thanks Rob - Now home and having dried out the carpets thoroughly, and cleaned the drain plugs properly, I have confirmed your message because I have had the radio out for several hours ... and no code needed when connecting it back up.
    Mike
  1. battery drain
    By jasey1007 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2008, 08:29 PM
  2. 1997 b5 front ash tray renoval help
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-05-2007, 11:42 AM
  3. Battery drain
    By nickasaki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2006, 01:51 PM
  4. Passat Battery drain
    By Blobnose in forum Passat - Archive Topics
    Last Post: 20-09-2006, 05:44 PM
  5. A3 Tdi Battery drain mystery!
    By moreski in forum Audi A3 - Archive Topics
    Last Post: 05-03-2006, 10:29 AM
