Thread: O2 sensor won't budge
  1. O2 sensor won't budge
    Jan 2010
    bury st edmunds
    I need to replace my 02 sensor on the cat but i can't loosen the old one.does anyone have any tips on how? It's in a tricky position and i am using the correct tool on the sensor but i am concerned about damaging the cat.
  2. Re: O2 sensor won't budge
    Oct 2009
    Ohio
    O2 sensors can be really tough to remove if they have been in the pipe a long time. You may try giving the edges a good tap to try and break loose the threads just a bit, then get the O2 sensor wrench on there. Once they break loose, they typically come out fairly easy.
  3. Re: O2 sensor won't budge
    Feb 2010
    Preston UK
    Quote Originally Posted by VW NORTON View Post
    Have you tried undoing whilst the exhaust is hot? this sometimes heats up the nox boss and frees the sensor but be careful no to burn yourself
  1. oil consumption not looking good
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-02-2010, 07:45 PM
  2. Please Help Passat B5 drivers door wont budge.
    By OpenRoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-10-2009, 09:35 PM
  3. car warranties
    By buster in forum Chat - Completely Off Topic
    Last Post: 22-07-2008, 11:50 AM
  4. Rear doors will not budge on 98 passat
    By pflangan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2008, 03:28 PM
