Thread: Fuel Consumption on my passat 1.9TDI
Results 1 to 10 of 13
  1. Question Fuel Consumption on my passat 1.9TDI
    Nov 2008
    Just wonder if this is normal I have passat 2003 1.9TDI 100BHP standard spec and I get 33MPG getiing to work, 7.8 miles is town driving with not to many stop start and 5.2 miles is just straight road at 50 MPH I converted MPG to L/KM and it is 8.5l to 100KM or 60 Miles, I got a friend who drive the same route in his BMW 330 petrol and got the same readings it looks a bit poor for diesel or is just me
  2. Re: Fuel Consumption on my passat 1.9TDI
    Norfolk
    The only way to get a clue about a possible problem is to have a full diagnostic check that looks at the actual sensor outputs, not just a code read.
  3. Re: Fuel Consumption on my passat 1.9TDI
    Apr 2009
    Leicester
    I have found that from cold and mainly town driving and a short run, that economy is around the 30-40mpg mark and I run the same 100bhp PD engine.
    I know the car runs spot on because on my run to school (45 miles) I average 50-52 mpg all day everyday so it is just the combination of stop start town driving from cold which drags the economy down.
    Is this a figure from the computer or from your own calculations?
  4. Re: Fuel Consumption on my passat 1.9TDI
    Nov 2008
    the figure is from my own calculation the computer on car showing around 38-40 mpg but thats just not right, is just a feeling that every week I do the same miles but every week by week I'm getting less for £20 if you know what I mean.
  5. Re: Fuel Consumption on my passat 1.9TDI
    Tyldesley, Manchester, UK
    Weather is very cold at present but it seems more in-line with my 130 petrol. I do about 8 miles motorway and 3 on the road. The congestion varies with the time (on flex) I go. Low 30's on the trip but about 29/30 in reality.
    One German, Two Italian.
  6. Re: Fuel Consumption on my passat 1.9TDI
    Jun 2008
    Hi, got my 130 tdi tuesday. Had a run yesterday to Malvern from Stafford...M6/M5, bit of tootling around the hills then a 3 hour stop start grind up the A449 through rush hour to Stafford.
    Computer reckons average 49mpg. Is this about right? If so I'm well chuffed.
    Car is just over 4 years with 42k and in good nick so this may be a factor?
    Ta
    D
  7. Re: Fuel Consumption on my passat 1.9TDI
    Nov 2008
    that's what i mean MalcQV I get petrol range not diesel, I will just keep eye on for next few days and see what will happend
  8. Re: Fuel Consumption on my passat 1.9TDI
    Good luck with that, there does seem to be a problem.
    I take it there is definitely no signs of a leak?
  9. Re: Fuel Consumption on my passat 1.9TDI
    Feb 2010
    monmouth
    I would expect minimum 50 out of my 110bhp passat estate but probably between 55 and 60. I have chipped here though and if you careful you can get 65+ cruising between 50 and 70mph
    seems very low
  10. Re: Fuel Consumption on my passat 1.9TDI
    Apr 2009
    Leicester
    It's not low for town driving.
    You will never get 50mpg out of a car if you drive around town with constant stop/starts.
  1. A6 1.8T Overfuelling
    By soulsearcher in forum VCDS - General Questions
    Last Post: 17-07-2009, 12:53 AM
  2. True fuel consumption
    By alogbe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-04-2008, 07:44 PM
  3. Replies: 0
    Last Post: 10-11-2007, 08:05 PM
  4. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
  5. OIL CONSUMPTION IN NEW PASSAT 1.9TDI
    By mac500 in forum Passat - Archive Topics
    Last Post: 02-05-2006, 03:45 PM
