Quote Originally Posted by stockcarss View Post
Hello I'm having similar issue after fitting a new alternator to my 04 plate octavia. As far as I can see I have not blown any fuses in the fuse box or those in the dash board compartment. I did have a couple of sparks while taking off the old one as I was lazy and did not undo the batter first. What was your soluition? I have checked the charging system with a multimeter and its only reading 11 volts as far as in know it should be putting out 13 if its working correctly. Any further suggestions will welcome.
iirc on top or beside the battery is 3/4 thick wires that have link fuses (50 amp i think) check thoses, also have you check the output on the back of the alt? with a running engine you should have a reading of about 14.2 volts with nothing on, with lights and heater on it should drop to about 13.7, it sounds ver much like one of the link fuses is blown or a wire is broken, it is common for the small wire on the alt to break down near the gearbox, a check on the back of the alt will help to guide you the right way mate
