Thread: strange moaning noise
  1. strange moaning noise
    Dec 2009
    harrogate
    hi there, i have a 1.9TDI 130 A3 2001. it failed its MOT the other day needed 3 new springs and new rear discs and a new suspention arm. i fitted a set of lowering springs (only 35mm) and some drilled and grooved discs and a standard suspention arm. it has now passed its MOT but on the road today i noticed that when i stopped accelerating and was just cruizing there is a faint moaning noise. does anyone know what this could be?
    Audi A3 1.9 TDI sport 130
    MODS: turbo back miltek (non res), ram air CAF, EGR delete, window tints, smoke side repeaters, R32 alloys 18", lowered 35mm on eibach suspension, alpine head unit, vibe space 15" subwoofer, hertz components.
    Still to do: Clutch, remap.
  2. Re: strange moaning noise
    Aug 2009
    leeds
    With out hearing it for my self i cant be too sure but it sounds like it could be a wheel bearing!
  3. Re: strange moaning noise
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Did you accidently run over the mot man ,and he's stuck under the car?
    Just kidding, if you have had the suspension assembly apart and up together again maybe something isn't quite how it should be, worth a quick look,or maybe now that the suspension is right and running true you could have highlighted a failing wheel bearing as said above.
    Alternatively without hearing the noise it's hard to say but potentially a leaking hose etc on the turbo/cooler, again might need some more detail of the moaning noise
    Stuart
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  4. Re: strange moaning noise
    Dec 2009
    harrogate
    i think its a wheel bearing, i have since found out that it is coming from the front drivers side wheel and i can only hear it when im at high speeds or when i let of the accelerator i can hear it as the car slows down. i will have a look when i get home this weekend. thanks.
  1. Strange alarm noise
    By martinA4passat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-12-2009, 03:00 PM
  2. Replies: 5
    Last Post: 02-11-2009, 10:44 PM
  3. Transporter van 57 plate strange noise
    By robbeyboys111 in forum The Commercial Range
    Last Post: 16-06-2009, 03:25 PM
  4. Strange noise....
    By Blocco A Spiral in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-08-2007, 08:08 PM
