Thread: headlights
  1. headlights
    my wife was driving home tonite, lights worked, she stopped at tesco, went to drive off 10 mins later, lights failed to work.
    side lights work, but dipped and full beam do not ( full beam works with the pull on the stalk, but goes out as soon as released ).
    any ideas? thought it may have been a relay, but have been told that the lights do no have a relay.
  2. Re: headlights
    Pembrokeshire
    22 Post(s)
    first job, check the bulbs. it wouldnt be the first case of lights not working, only to find both bulbs gone. second job, check the fuses. just looked and there is a fuse for each side, no1 & no 2, so unlikely both have gone. i would then say its either bulbs or switch.
  3. Re: headlights
    Thanks - have tried both with no joy...
    Any further suggestions greatly appriciated!
  4. Re: headlights
    Jun 2008
    Lichfield, Staffordshire
    sounds like the headlight switch itself is at fault, the stalk pull for main beam being a different circuit.
    If you have a friend with the same age golf, try swapping the switches over.
    sorry, can't be much more help
  5. Re: headlights
    Sep 2009
    South Wales
    I had this happen to my car the other week, turns out that my connectors were loose going into the headlamps, try pushing the connections in and making sure theres no break and the earth is good.
    I lost earth on a relay and my lights wouldnt switch from sidelights to main/dipped. Try that before you rip your car apart.
    You can always test the lamps by running a 12v and a gnd into the bulbs, just make sure you put a fuse on it, 1-2 amps on the 12v line should sort it (assuming 55w bulb anyway)
  6. Re: headlights
    Jul 2009
    Best way to check bulbs is to stick them on a little 9v battery, if they light up they are fine.
    Grab yourself a multimeter and check you have live and earth on the headlights first.
    I like Golfs. Nothing beats the feeling you get seeing the chav that just overtook you in his french car on the hard shoulder.
  7. Re: headlights
    problem solved.
    it was the headlight switch on the dashboard,
    got a replacement off ebay for £ 8 including postage.
    works like a treat.
    thanks for the help.
  1. Question Bora Headlights Always On
    By Bandicoot in forum Bora - 1998 - 2005
    Last Post: 25-10-2009, 11:32 AM
  2. A4 Avant 1.9Tdi Sport, Dull headlights
    By retailandtrade in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-05-2009, 12:32 PM
  3. Automatic headlights
    By JonBuoy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-05-2009, 09:49 PM
  4. Headlights come on when I lock/unlock my car?
    By rick_s in forum VCDS - General Questions
    Last Post: 02-03-2008, 12:22 AM
  5. Headlights went out on A4
    By former dallas eagle in forum Chat - Anything with wheels
    Last Post: 11-03-2007, 06:09 PM
