Thread: vw t4 starting problems again!!!
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: vw t4 starting problems again!!!
    Oct 2009
    ipswich england
    Hi thanks any suggestions i have had a look at the amount of wires behind the box once pulled out there is loads if they made them 2 feet longer would be easy but can only get 6" behind but loads are not even connected but have seen major red one which i assume is battery in far right corner looking at unit ?? I would imagine from what i said in my last posts that it's nothing under the bonnet just electrical but i guess that would mean going from wire to wire to eliminate gggrrrrr
  2. Re: vw t4 starting problems again!!!
    The fact you said you moved the relay in the holder,then the control light came on suggests a fault with the holder.the terminals inside the holder are riveted,and sometimes work loose,and there is really nothing you can do with it other than replace it.I would test it again and the next time the glow light does not come on just wiggle the relay and see what happens,to eliminate a possible faulty connector in the wiring harness
    2 0 0
  3. Re: vw t4 starting problems again!!!
    Mar 2022
    Manchester,uk
    Hi I have the same problem…. Did you resolve it ?? Any advice for me?? Tia….. Billy
  4. Re: vw t4 starting problems again!!!
    1836 Post(s)
    Quote Originally Posted by Billyurl View Post
    Any advice for me?
    Yes, start your own thread in the appropriate section and don't resurrect 12 year old posts...
  1. Please Help Starting and idleing problems!!!
    By species in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2010, 02:29 PM
  2. VW Fob problems !!
    By Louis 73 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2010, 03:57 PM
  3. vw 1993 starting problems car turns over fine
    By 3123marriott in forum Golf MK3 - 1993 - 1999
    Last Post: 25-12-2009, 07:38 PM
  4. Please Help Problems starting from cold/ warranty issues
    By lcleme in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 23-09-2009, 07:45 PM
  5. mk4 1.6 ignition coils failure - VW out of stock
    By john.bevan@virg in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2007, 12:51 PM
