Thread: A6 Avant Fuse Blocks and Numbers
  1. A6 Avant Fuse Blocks and Numbers
    Jan 2010
    Bridgwater, England
    Hi - my Audi Manual has a section for Fuses and Bulbs in which it gives pictures and tables for the fuse blocks and numbers.
    The problem I have though, is that I have just removed my fuse box covers, and they don't seem to match the manual. I am guessing that this may be due to the manual being depicted for a Left Hand Drive vehicle?
    Anyone else had this problem, and does any one know of any right hand drive diagrams\tables, that clearly depict each fuse and its use.
    Cheers.
  2. Re: A6 Avant Fuse Blocks and Numbers
    Oct 2007
    I think if you look hard enough you will see the fuses are numbered,very hard to see though black on black
  3. Re: A6 Avant Fuse Blocks and Numbers
    Jan 2010
    Bridgwater, England
    Thanks Kenney
    I will put my specs on and have a closer look tomorrow!
  1. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  2. A6 Smoking Exhaust on Braking
    By John McCavert in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-05-2009, 10:32 PM
