Thread: AC Issue, Compressor Shut-off From ECM (Code 12)
Results 1 to 10 of 18
  1. Question AC Issue, Compressor Shut-off From ECM (Code 12)
    Apr 2024
    Baldivis Australia
    I've been banging my head against a wall with this one. Ever since owning my 2008 Mk5 1.9L TDI Golf. I've never been able to figure out why the AC does not blow cold air. More specifically why the ECM is commanding the compressor to not engage.
    I've scanned the car and there are no faults in the Engine or HVAC Module, All the sensors are working and reading within expected range (Replaced the N280 annd G65) No leaks in the AC System and been Regased.
    Compressor and Radiatior fans confirmed working after manually bypassing the ECM and engaging the N280 Solenoid / hard wiring the fans; cold air came out. Fuses checked.
    So I'm 99% sure the ECM is receiving something it's not happy about and is to my understanding "load shedding" systems. But unfortunately I haven't been able to find any information as to what causes it to spit the dummy! Other than a possible vacuum leak in the brake system. But I have isolated that and believe there's no issue there. again nothing found on live scans through OBDeleven.
    I've literally searched for hours and hours going the SSP's, Wiring diagrams, Forums and random youtube vidoes spoken in russian trying to get to the bottom of it. Can someone please help!
    Thank you!
  2. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Dec 2014
    Bedford
    42 Post(s)
    Do you have a shut-off code for the compressor?
    What scan tool are you using?
    From memory, go to 08 hvac ,measured value block 1 field value 1 and see what it says.
    Sent from my SM-G996B using Tapatalk
  3. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Apr 2024
    Baldivis Australia
    I’m using OBDeleven. It’s the shut-off code 12
  4. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Dec 2014
    Bedford
    42 Post(s)
    Shut off by ecm via canbus, let me think on it. It's a bit early.
  5. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Apr 2024
    Baldivis Australia
    Thanks mate I really appreciate it
  6. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Dec 2014
    Bedford
    42 Post(s)
    Any other faults anywhere else , mainly engine? Brakes?
    I think.the ecu is reducing the load on the engine because there's either a temperature fault somewhere in hvac , or engine needs more vacumn. Can you see ac pressure readings in obd11.
  7. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Dec 2014
    Bedford
    42 Post(s)
    Try measured value block 54 display 4
    Display zone 4
    Status of refrigerant pressure/temperature sender -G395.
    The status is transmitted via the data bus system of the air conditioner LIN bus to the Climatronic control unit -J255.
    J Readout = "0000XXXX" (breakdown)
    Example
    J Readout = "00000000" (no fault in refrigerant pressure/temperature sender -G395).
    Breakdown of readout in display zone "4" of display group "054"
    Allocation of possible fault types
    J Readout = "0" (no fault)
    J Readout = "1" (this fault detected)
    Readout = "0000XXX1"
    Measured value of installed pressure sensor faulty
    Readout = "0000XX1X"
    Measured value of installed temperature sensor faulty
    Readout = "0000X1XX"
    Fault in one of the two installed sensors or in the electronics
    Readout = "00001XXX"
    Fault in electronics of the refrigerant pressure/temperature sender -G395
    Red highlighted bits currently not used
  8. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Apr 2024
    Baldivis Australia
    Hey mate, AC pressure reading is through the G65 sensor for this Golf (checks out fine) see attached screenshot.
    Screenshot_20240412_134509_OBDeleven.jpg.
    Somethinng that has piqued my interest however is the Radiator fan activation (Actual) vs (Specified). The specified in this screen shot is 36%. But there was no movement in the fans. Once the coolant temp rose to above 90 Degrees they then came on. What I think is happening is the HVAC is commanding the fans to come on with AC activation but maybe having a communication issue to the fan control module? The Engine control module is still able to command the fan control according to the engine temp annd cooling requirments? Possible fan control unit issue??
  9. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Dec 2014
    Bedford
    42 Post(s)
    Yes, could be, theres 2 small wires on fan yellow is ac activated by ac module, red is ecu, the fan controller is also inside the main fan, so if yellow is being pwm generated it could be the controller inside fan.
  10. Re: AC Issue, Compressor Shut-off From ECM (Code 12)
    Dec 2014
    Bedford
    42 Post(s)
    But there is probably a fuse as well for the fan inside e box by battery.
  1. Replies: 0
    Last Post: 02-09-2017, 09:37 AM
  2. Meaning of compressor shut off code
    By TheFixer in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-09-2012, 10:03 PM
  3. Allroad air compressor vs. A6 rear self leveing compressor
    By g.suggy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-06-2012, 11:00 AM
  4. Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    By Max-Power in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-01-2010, 01:35 AM
  5. MKIV Golf Fault Code: P1609 "Crash shut-down activated"
    By laugharne in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2007, 08:05 PM
