Thread: Faulty Oxygen Sensor
  1. Question Faulty Oxygen Sensor?
    Aug 2007
    Cork, Ireland
    I'm getting 2 fault codes on my AWT 1.8T.
    17536 - Fuel Trim: Bank 1 (Mult): System too Lean
    and
    17544 - Fuel and Trim: Bank 1 (Add) System too Lean.
    I checked the reading for the MAF and it appears to be in range, but the oxygen sensor starts off at 0% then jumps to 22% and it goes between 2 fixed values of 22% and 26%.
    I've another A4 with a 1.8 ADR engine, would they be the same part to swap test?
    Thanks in advance.
    4 Audi's or is it 4 Audi?
    02 - A6 Avant 1.9 TDi 130 Sport
    01 - A4 Avant 1.8T Sport
    98 - A4 Avant 1.8 SE - Bye bye Bluey
    92 - 80 Saloon 2.0 - My first love (for 10 years)
  2. Re: Faulty Oxygen Sensor
    Sep 2007
    stone,staffordshire
    yo, if the plugs are the same the sensors should be safe to swap. an air leak could also cause the fault. the sort of readings you want of a lambda/oxygen sensor are ( with the engine a operating temperature ) well full range is normally 0-1volt , 0.000 - 0.999v the readings should sweep from high to low all the time eg 0.200-0.900 then 0.150-0.700 then 0.400-0.800 pretty random but normally from under half a volt to over
    . hope this helps
    regards sid
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
