when I turn headlight switch off the lock actuator/rod is opening the tailgate.Also while trying to solve this problem I have found that if I disconnect the harness plug from the back of the headlight/sidelight switch with it in the off position and turn the ignition to on but not start the headlights and side lights are all on,is this normal? Car is a 04 A4 TDI Avant
