Thread: Brake Problem HELP....
Results 1 to 10 of 10
  1. Brake Problem HELP....
    Jun 2008
    Plenum filled with water, Servo Knackered......
    I know all the previous threads on this indicate Brake Servo replacement, but can anyone give me a link to show how to replace it?.... Don't want to tackle it blind! If anyone can point me in the right direction I'd appreciate it, as I really want to do this today!
  2. Re: Brake Problem HELP....
    Norfolk
    Car details, engine etc are??
  3. Re: Brake Problem HELP....
    Jun 2008
    2001 Tdi 130 ..... Got the servo done, now all I need is someone to help me bleed the brakes.... Anyone give me the rundown???
  4. Re: Brake Problem HELP....
    Oct 2007
    Build-up brake pressure in brake system by pumping the brake pedal.
    Attach bleeder bottle hose and open bleed screw.
    Close bleed valve with pedal held down.
    Repeat operation until no air is present.
    Bleeding sequence:
    1. Rear right brake caliper
    2. Rear left brake caliper
    3. Front right brake caliper
    4. Front left brake caliper
  5. Re: Brake Problem HELP....
    Jun 2008
    Cheers Kenney, I'll give it a go.... Is the order important?.. If so, Why???
  6. Re: Brake Problem HELP....
    Oct 2007
    It's just the order of procedure,not very important though
  7. Re: Brake Problem HELP....
    Jun 2008
    If you decide to use an easy bleed system still pump the brakes as myself and somebody else i know have had problems with air locks even though this bit of kit is supposed to prevent that from happening.
    I would recommend pumping the brake a minimum of at least 12 times per corner.
    I had my brake fluid changed recently and even though when they bled the brakes and the pedal felt firm as i drove the car away the pedal went to the floor. Not a good feeling.
    Made it back ok and got them to do the brakes again and more air bubbles came out of the rear brakes. Probelm sorted.
    If it ain't broke leave it alone!!!
  8. Re: Brake Problem HELP....
    Dec 2009
    I'm having the same problem on 2002 TDI 130. Taken to main dealer today for plenum recall and they have confirmed water in the brake servo. Claim raised with VW customer care and quoted £600 for repair. Ouch. Is it possible to drain the water from the servo? I will keep an eye on the water level in the plenum from now on.
  9. Re: Brake Problem HELP....
    Norfolk
    Once the servo is damaged by water getting in it needs replacing. It is too dangerous to risk this failing at high speed. In theory you can still stop with no servo assistance but it is far from easy and not something you want to find out.
  10. Re: Brake Problem HELP....
    Dec 2009
    Just an update. The servo was replaced free of charge thanks to VW customer service. Had to wait 3weeks for a servo but better than £600. Two days after getting the car back I get a recall from VW about the brake servo water ingress.
  1. Brake pedal sensor intermittent...
    By JohnW78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2009, 11:43 AM
  2. polo 1.4 tdi - intermittent starting problem and ABS
    By maxeymoo in forum Polo - Derby - Lupo - Fox
    Last Post: 07-12-2009, 12:09 PM
  3. brake assistnce problem
    By evsy125 in forum 80 - 90
    Last Post: 12-08-2007, 08:50 PM
  4. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
  5. Brake Pad replacement - Wear Sensors Problem
    By duncan89 in forum Passat - Archive Topics
    Last Post: 22-05-2006, 08:46 PM
