Thread: Plenum chamber cover removal?? Help please.
  1. Plenum chamber cover removal?? Help please.
    My wife has just bought our first passat 130 TDI SPORT ESTATE, I've read about the plenum chamber problem, have taken the battery cover off but am unsure how to remove the rest of the black plastic cover so i can have a look at the chamber itself and try and locate the holes,
    I know this is a well documented problem on here but i'm new to passats myself and just need a bit of advice.
    Any help please would be appreciated.
  2. Re: Plenum chamber cover removal?? Help please.
    Jun 2006
    UK, Mids
    You have to 'pee'l off the rubber seal that seals against the bonnet. The cover then slides back with a tug until it hits the bonnet struts and can lifted off. Take a note of how the corners of the seal look and how the bonnet release cable is routed into a channel on it before removing.
    Audi A8 - 2015 - 3.0TDI
  1. At last! A uk recall for the passat brake failure water leaks plenum chamber
    By snapdragon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2016, 11:27 AM
  2. Car breakdown cover from chris knott insurance
    By Tim@ChrisKnott in forum VW Audi Forum "Preferred" Insurance In association with Chris Knott
    Last Post: 21-04-2011, 09:17 AM
  3. No plenum chamber cover on 2004 1.8T S-line.
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2009, 10:53 PM
  4. Plenum chamber recall
    By Stu8 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-04-2009, 09:30 PM
  5. Please Help plenum chamber cover
    By arman123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2009, 10:15 PM
