Thread: Mk4 golf air filter
  1. Mk4 golf air filter
    Feb 2006
    Hi Guys,
    i have just bought a KN panel filter for my Golf GT TDI 130.
    can i ask if this is easy to install, if so how do i take out the old filter.
    also will the KN panel make much difference?!
    kind regards
    Daniel
    Feb 2006
    Yorkshire
    Hi Daniel............i'm not a 100% but there should be a piece of intake tube that runs from the air box to the maf sensor , its should be held on by way of a clip...undo the clip so as to give you some play at the filter box end.
    Now open the filter box by unclipping 4/5 clips that hold the top of the air box in place then take out the oem paper filter and replace with the k&n , also clean out the filter box with a hover if ther are some small dirt like particles in there.
    Now when you refit the filter box lid make shaw you have a complete air tight seal because if you don't it can cause it 1 let dirt pass into the maf and turbo and 2 it will then make a big swoooooshing sound plus lots of smoke out back.
    This does'nt make alot of a performance difference other than hearing a larger intake sound and also a little better spool up , Some people have reported by changing to a 2.5" exhaust straight from the turbo with no cat,mid box, or back box = exhaustoctomy and changing the inlet manifold and pipe work a larger hp gain can be made but more over spool up and a couple of psi more seems to be the most gained here.
    My mk3 1Z motor has such a setup plus a T28bb turbo,high lift cam,2.0L pistons,hardoned rods,large b/plate intercooler,larger 520 race injectors, and hopefully in the next month or so 250hp when its live mapped.
  1. Golf V5 Oil Filter
    By Supatek in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-09-2007, 10:58 PM
  2. help Where is the oil and fuel filter MK5 2004 Golf
    By daveaustin in forum Golf MK5 - 2004 - 2009
    Last Post: 25-04-2007, 08:15 AM
  3. How do i change the oil filter 2004 Golf 2.0 TDI
    By daveaustin in forum Archive posts
    Last Post: 17-04-2007, 11:34 PM
  4. Golf V5 oil filter.
    By petercooke in forum Archive posts
    Last Post: 07-02-2007, 12:15 PM
  5. mk4 golf air filter
    By daniel_louis in forum Golf MK4 - 1999 - 2004
    Last Post: 16-02-2006, 02:12 PM
