Thread: Please help. Knocking noise from wheels
  1. Please help. Knocking noise from wheels
    Sep 2009
    wales
    I have a problem with my 2004 MK5 TDi
    There is a knocking noise coming from the wheels when i'm tuening the wheel.
    The noise seems to happen when driving off whilest turning or going slow when turning. (Not when driving in a straigh line) Knocking only happens when the wheels are getting driven, if i stop at a stand still and turn the wheel it doesn't knock
    Anyone have any ideas what the problem is?
    Your help would be much appreciated
    Many Thanks
    Dave
  2. Re: Please help. Knocking noise from wheels
    Sep 2009
    London
    It is either the wishbone or cv joint, would check the jv joint first.....
    Stick your head out the window when turning and focus to which side the noise is coming from, you could get someone in the passenger seat too, im sure it is only one side. Best way to check the problem is to have the car put on the ramp, manually spin the wheel as fast as possible and turn the steering wheel, the fault should turn up then.
    Let us know if you found the problem, cheers.
    2004 golf mk5 with retrofitted: cruise control, MFSW, Highline clock diplay, angel lights.
  3. Re: Please help. Knocking noise from wheels
    Sep 2009
    wales
    Had a new tyre fitted today so they took a look under to see
    They tell me it is the n/f/s drive shaft that is knackered
    Can't seem to find one anywhere, cheap that is!
  1. A4 1.8 B5 Knocking noise after timing-belt done
    By sanstorm999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-08-2011, 06:35 PM
  2. New member needs help: knocking noise VW Bora 1.6SE
    By mamasboy in forum Bora - 1998 - 2005
    Last Post: 31-01-2010, 10:35 PM
  3. VWT4 1999 Auto 2.5tdi. Knocking noise...
    By pblucas in forum The Commercial Range
    Last Post: 06-10-2009, 04:26 PM
  4. Golf Knocking noise help please!
    By k3v in forum Golf MK4 - 1999 - 2004
    Last Post: 18-10-2008, 09:07 PM
  5. How does the Quattro system work?
