Thread: Problem foot well lights
Results 1 to 10 of 17
  1. Problem foot well lights
    Sep 2009
    United Kingdom
    Although my “foot well” lights (supplied as part of the luxury pack) come on, and then dim along with the interior lights when the doors are open and then closed, they never extinguish completely.
    They only work when either side or headlights are on, but having illuminated feet seems an unnecessary luxury!
    The car has been back to the dealers but they seemed unable to rectify the problem.
    Has anyone else encountered this problem and found a solution?
    (I don’t have a MFD just the standard)
  2. Re: Problem foot well lights
    Sep 2009
    Tamworth
    I've got the footwell lights on mine but i have the highline computer and i can adjust the brightness of the lights
  3. Re: Problem foot well lights
    Sep 2009
    United Kingdom
    Johnnny - Thanks but I'm not so worried so much about the brightness as them never going off - I assume yours do eventually?
  4. Re: Problem foot well lights
    Sep 2009
    Tamworth
    ner they stay on all the time but i think there is an option to do it but i am not to sure how to go about it without MFD.
  5. Re: Problem foot well lights
    Aug 2009
    oxford
    They are on all the time your lights are on, but I think, and am prepared to be shot down here, that you can turn them off and down on the MFD.
    They are great I have turned mine up to 75%, the wife can rummage in her handbag for hours without having to destroy my night vision by turning on the overhead lights.
    In new civic it is all the rage to fit blue or red LEDs in the footwells for mood lighting, and they are bright
    Golf mk6 GT TSI 160 3 door Black with convenience pack
  6. Re: Problem foot well lights
    Apr 2009
    Quote Originally Posted by slowhand View Post
    I know I can definitely adjust the brightness with the highline, not sure what it goes down to though as I like to keep mine on too, I like them
    Arrived on 29th September: MK6 Golf Bluemotion SE - Reflex Silver
  7. Re: Problem foot well lights
    Sep 2009
    United Kingdom
    Hi, I just checked with VWCS and they advise at present you CAN’T turn off the foot well lights.
    My dealer has raised the problem with VW Germany and I apparently I will have wait until they respond with a solution. The dealers VAG COM check shows no problem with my car - except the lights only dim and don’t extinguish!
  8. Re: Problem foot well lights
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by johnnny View Post
    I have them but I don't recollect you being able to change the brightness in the Highline only the time they are on for, 10 seconds default settings. Someone asked about the brightness in another topic can they fit larger bulbs a few weeks ago but I didn't read all of it.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  9. Re: Problem foot well lights
    Jan 2010
    Romania
    You can with a little help from VCDS:
    Module 09-Cent Elect-Coding BCM-byte12-uncheck bit 5.
    Ask someone to help you and your problem will be solved
  10. Re: Problem foot well lights
    Steve_D Guest
    Quote Originally Posted by Keithuk View Post
    Definately can turn them up/down/off on mine. They are on all the time the lights are on. Once into the settings on the dash, you can turn them up/down in 5% increments between 0 and 100%.
  1. Golf GTi 16v idling problem - stalls when cold
    By garymansell in forum Golf MK3 - 1993 - 1999
    Last Post: 23-08-2009, 05:05 PM
  2. FLICKERING lights on Dash (pre-ignition)
    By andysuth in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-08-2009, 12:07 PM
  3. Problem with Dashboard lights
    By eskimo in forum Golf MK3 - 1993 - 1999
    Last Post: 15-02-2008, 04:12 PM
  4. Mark 4 Golf Starting problem.
    By Oztrexx in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2008, 01:08 AM
  5. courtesy lights problem
    By scotty33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2008, 12:16 AM
