Thread: Knocking noise help plz a3 54 plate
  1. Knocking noise help plz a3 54 plate
    Oct 2007
    This in the problem ever time i turn right im gettin a knocking noise front the front.It sounds like the drivers side.It doesnt happen any other time any help would be grate ful.
    audi a3 54 plate 83k
    any help would be great
    thanks
    gav
  2. Re: Knocking noise help plz a3 54 plate
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Quite a few things to look at
    1,wheel nuts
    2,suspension bushes
    3 shocker mounts
    4,shockers
    5,c/v joints
    6,steering joints
    7,anti roll bar anchor point/bushes
    8 wheel bearings
    Get her up in the air and have a good look and tug about
    Stuart
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  3. Re: Knocking noise help plz a3 54 plate
    Nov 2009
    Fleet / Hampshire
    As per fourringsrus reply, any of those could be possible.
    Certainly from experience, if your CV boot has split and over time the packing has leaked, then effectively the ball joint of the drive shift is then free to move around - hence the knocking noise. Which as you describe is more apparent on turning circles.
    So this needs to be sorted quickly otherwise instead of just paying for a new cv boot to be fitted which costs enough itself, then a whole new drive shaft may be needed which then means both sides!!!
    In short get it looked at sooner rather than later to save your pocket
  1. World Debut For The All New Audi A3 Cabriolet
    Last Post: 01-12-2007, 06:56 PM
  2. Knocking noise in engine
    By marathon in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-05-2007, 06:16 PM
  3. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
  4. Audi A3 sportback strikes the best balance
    Last Post: 31-07-2004, 08:36 PM
  5. Unique look for Roomy New Audi A3 Sportback
    Last Post: 23-06-2004, 10:36 PM
