Thread: How to Fit Drop Links
Results 1 to 10 of 14
  1. How to Fit Drop Links
    Feb 2009
    Did the links but still got knocking on uneven roads !
    any ideas????????
    hi
    re earlier post...i have now discovered it is the anti roll bar drop-links.
    i have just got a price for them from a local supplier and am attempting to renew them myself tomorrow!!!!
    any tips??
    i am going to use axle stands to keep the front end level but wondered if i need to support the anti roll bar itself?
    any pics or tips will be greatly appreciated
    cheers
  2. Re: How to Fit Drop Links
    Pembrokeshire
    22 Post(s)
    just support the front, with both wheels off the ground and replace the links. simples. no need to support the bar.
  3. Re: How to Fit Drop Links
    Feb 2009
    cheers zollaf
  4. Re: How to Fit Drop Links
    Apr 2009
    Preston
    once your under the car and looking at them im sure you will find them easy to do...just ensure you put the right ones on each side and dont do what the numptys a vw did and put the wrong ones on!!!!
    Y90USF
  5. Re: How to Fit Drop Links
    Jun 2006
    UK, Mids
    If they are the later solid bush type. Make sure you tighten the bolts while the car is on the ground and the suspension is settled down.
    Audi A8 - 2015 - 3.0TDI
  6. Re: How to Fit Drop Links
    Feb 2009
    did them toady and youre right they are pretty easy. got dark so car still on axle stands on drive. it must be very difficult to tighten once car is lowered as there wont be a great deal of space?
  7. Re: How to Fit Drop Links
    Jun 2006
    UK, Mids
    It's probably not so bad for roll-bar links as they are cheap and no that critical and maybe not that much deflection, but if you tighten bolts through bushes in the air, the bushes will twist up when lowered and soon be ruined.
    A garage would use a lift and have the car stood on the ramp.
    You can lower it onto breeze blocks, or leave them loose and get an exhaust centre to nip them up for a couple of pound.
  8. Re: How to Fit Drop Links
    Feb 2009
    Cheers snapdragon .
  9. Re: How to Fit Drop Links
    Feb 2009
    Did the links but still got a knocking !
    Any ideas ? Only when I go over ridges in road or bumpy road. If its fairly good road, no knocking.
  10. Re: How to Fit Drop Links
    Jul 2008
    South Wales
    Ive had exactly the same on my 03 tdi sport for over a year now. Its been in to many garages and the only thing one could find was the upper "twisted" arms bushes. (sorry, dont know the correct names) this didnt stop it at all! I suppose whatever is worn is causing other components to wear too. Its like a clicking sound over uneven roads as you describe, although strangely not over large bumps like speedbumps. I also have a loud click when accelerating from a stop. Possible engine mounts? what do you think?
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. A4 Front Drop Links
    By kevmayer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-06-2009, 06:20 PM
  3. Replacing A4 anti roll bar drop links 96 1.8T
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-08-2007, 07:35 PM
  4. Passat B5 drop links
    By sjs117 in forum Passat - Archive Topics
    Last Post: 26-01-2007, 05:44 PM
  5. Volkswagen Express Fit saves customers money
    Last Post: 03-07-2004, 08:18 PM
