Thread: Tow bar electrics
Results 1 to 10 of 11
  1. Tow bar electrics
    Sep 2009
    Chorley
    I'm going to get a bar fitted to my TDI 170 sport but am loathed to spend the amount quoted by VW (best part of a grand). Local fitters will put one on for around £250 using the industry wide standard bypass relay. VWsay use the proper harness insert and re programme the ecu. I'm not bothered about the reprogramme bit to be honest but would like to know if anyone has used the cheap option of a relay and had any problems with the cars electrics?
  2. Re: Tow bar electrics
    Norfolk
    If you use a bypass relay and run new 12v supply from battery or fuse box you have no problems. The can-bus system won't even know it's been fitted.
  3. Re: Tow bar electrics
    Jul 2007
    Had my bar fitted by EECO at Halifax using a by-pass relay over three years ago (£215.00 fitted including S/S bump-plate, chrome flipper, VAT and cup of tea) whilst I waited and have had no problems.
    When I asked the dealer about the stability system with a `proper` harness they denied one existed and even claimed to have searched their computer for such a thing and drew a total blank (confidence inspiring, huh?).
  4. Re: Tow bar electrics
    Dec 2008
    Sale
    Mine was fitted by North West Towbars in Stockport for £249, it works as it should so I wouldn't worry about any issues.
  5. Re: Tow bar electrics
    Feb 2009
    Had mine done at a palce in Stoke on Trent. It's called Autow Bar and he uses an aftermarket harness and puts it on the VAGCOM to program it. Cost about 300 or 350. Nice job.
  6. Re: Tow bar electrics
    May 2008
    Derby UK
    Hi,I fitted mine myself using 13 pin towing socket and bypass relays, i used the 12v socket in the load compartment (Estate) which has a 15 amp fuse protecting it. Everything works fine i've towed a caravan for 2years since i installed the tow bar and electrics with out problem the cost was about £175 including a Bosal swan neck towbar. Have a go yourself its quit easy for instruction on how to fit the tow bar go on to Witter towbars site it shows you how to take the bumper,rear lights off etc.
  7. Re: Tow bar electrics
    Staffordshire
    I fitted mine and my fathers towbars both passat estates with the Wesfalia detachable, the same one that VW would fit if you took it to them. there is a place in the tool tray in the boot for the detachable part when you are not using it. i used the bypass relays and two years on i have had no problems. for the power supply i ran a 30Amp cable from the battery with a in line fuse 25A. one thing i would advise for the twin sockets i got 2 inline sockets, they pack away behind the bumper and you dont have to get on your hands and knees to plug the caravan in
    2011 Passat Estate TDI 140 SE: Iron Grey, Heated seats, folding mirrors, 2 Zone climate, Detachable towbar, Arrived 2 weeks early 15/07/2011
    2008 Passat Estate TDI 140 SE:- Arctic Blue (SOLD)
    1974 185bhp Tdi Range Rover Mercedes Powered (running on straight veg oil)
  8. Re: Tow bar electrics
    Mar 2008
    This is my experience of a relay towbar
    https://www.vwaudiforum.co.uk/forum/s...456#post363456
  9. Re: Tow bar electrics
    Solihull
    I fitted my towbar myself and opted for a vehicle-specific wiring system. The electrics cost more than the towbar - about £130 - and were a real pain to fit. I had to run the harness all the way to the front of the car, removing trim panels all along one side to feed it through.
    There were five wires to connect - two to the fuse box, two to the canbus and one other. I haven't bothered to have it coded yet.
  10. Re: Tow bar electrics
    Sep 2009
    Chorley
    Thanks for the information. I'm going to go for the bypass relay option. Next chioice is detachable or fixed?????
  1. Towbar preparation MY2010
    By vincentbob in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-07-2012, 07:17 PM
  2. Golf Mk 6 tow bar
    By dorsetgolf in forum Golf MK6 - 2009 - 2013
    Last Post: 12-11-2009, 05:03 PM
  3. Question Mk3 golf tow bar electrics general question
    By robert1z in forum Golf MK3 - 1993 - 1999
    Last Post: 27-10-2009, 07:31 PM
  4. sharan tow bar electrics
    By deano224 in forum Touran - Sharan - Caravelle
    Last Post: 13-08-2009, 01:01 AM
  5. Question Tow Bar electrics, is it worth buying a specific wiring kit?
    By RobsA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-05-2008, 10:06 AM
