Thread: Anti Roll Bar Bushes
Results 1 to 8 of 8
  1. Anti Roll Bar Bushes
    Feb 2009
    How difficult is it to renew the anti roll bar bushes at the front ens of a passat tdi (2003)??
    Had car in for service yesterday and they advised the clunking noise ive been hearing may be worn bushes. If its cheap enough, i may get the independent to do it. Any ideas on price at independents?
    Can anyone shed any light on the above? if there are any pics to accompany the above job, it'd be helpful.
    Thank you
  2. Re: Anti Roll Bar Bushes
    Norfolk
    A "C" shaped link with a rubber bush in each end joins the roll bar to the track control arm. The links cost about £30 each from VW. Simple nut and bolt job as long as nothing is siezed.
    Don't tighten bolts until car is back on the ground.
  3. Re: Anti Roll Bar Bushes
    Apr 2009
    Preston
    independent shouldn't charge you much for fitting these i paid my independent a tenner to fit these.
    Y90USF
  4. Re: Anti Roll Bar Bushes
    Feb 2009
    Thanks guys . Going to speak with garage. Tomorrow.
  5. Re: Anti Roll Bar Bushes
    Jun 2008
    have just took c link off and got new one on i seen here that ya dont tighten them til car is on ground again is this link arm supposed to be straight up and down because wen car is on ground the arm is sitting at an angle
  6. Re: Anti Roll Bar Bushes
    Jun 2006
    UK, Mids
    Quote Originally Posted by mark78 View Post
    Yes, always tighten any rubber bush with the car on the ground, (VW say with 75Kg weight in the front seats and full tank of fuel).
    If you tighten in the air, the metal bush in the centre of the rubber is locked when the car is in the air, then when you lower it, it turns and twists the rubber bush up like a clock spring. Then when you go over a bump, it twists further than it was designed to and rips past it's elastic limit and is ruined.
    Audi A8 - 2015 - 3.0TDI
  7. Re: Anti Roll Bar Bushes
    Jun 2008
    thanx for the quick reply so it doesnt have to sit straight up and down thanx again
  8. Re: Anti Roll Bar Bushes
    Jun 2009
    Telford UK
    Hi Mark
    Just done the Anti roll bar bush's not the c shape drop links yet and it was simple
    Lemforder from Euro Car parts for £11 for 2 and did it on the drive with Jack - ramps nad axel stand and only undoing the the front underside plastice cover...
    Use the ramps under the wheels for when you let it back down before tightning the bracket..
    Give the car a good bounce at the front before you fully tighten...
    C Shape anti roll bar links next.... im looking at £52 for lemforder from ECP
    Good Luck
  1. anti roll bar bushes
    By Alasdair999 in forum The Commercial Range
    Last Post: 17-10-2009, 11:42 AM
  2. Passat Anti Roll Bar dia
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-09-2009, 09:32 PM
  3. 99bora anti roll bar bushes
    By LOL3059 in forum Bora - 1998 - 2005
    Last Post: 26-05-2009, 12:42 AM
  4. Front Anti Roll bar Bushes - How much??
    By CPD in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2008, 06:05 PM
  5. anti roll bar bushes
    By sean red i in forum Audi A4 - Archive Topics
    Last Post: 02-01-2007, 01:20 PM
