Thread: Where's injection pump timing hole?
Results 1 to 10 of 14
  1. Where's injection pump timing hole?
    May 2007
    Have a 1999 V reg Golf TDi 110 hp I am changing the cylinder head due to damage.
    My question is where is the injection pump timing hole?
    Have bought the camshaft locking tool but cannot see the injection pump timing hole it is either very small or you have to take the cog off which will loose the timing!!
    There are three slotted bolts on the pump.
    Help!!
    May 2007
    Anyone awake in VW/Audi forum land?
    Canada
    http://tdiclub.com/articles/A3-TimingBelt/
    this should give you a better idea.
    Rob.
    (must go to sleep now )
    May 2007
    Thanks for the pictures but my injection pump is different it is virtually solid with 3 bolts that are in slotted holes.
    Can I wake anyone else up?
    May 2007
    Got mechanical timing perfect camshaft with locking bar and crankshaft flywheel marks perfect but still no one can tell me how to time the injection pump PLEASE HELP!!
    May 2007
    Please help someone on VW/AUDi forum must know.
    May 2007
    It must be possible to tell where the injection pump should be timed how do you do it if the cam belt breaks? or how do they do it at the factory?
    Canada
    I haven't time an injection pump, but i was readin somewheer, i wish i could remember, that to time the pump in properly you need a pump dial gauge. this basically tell you where the pump timing is. in not the same as locking it. as the timing on the gear is already set at the correct point.
    This may be twadle, or at best slighty inaccurate but it should give you a few words to seacrh on at least.
    (I think I going to ask my resident expert, my dads a (retired) mechanic )
    Rob
    Canada
    Thats the tool you need
    http://www.dieselvw.com/IDI.htm
    Canada
    This look even better
    http://www.vwdieselparts.com/injtim.htm
    Rob
  1. VW Transporter 1993 Injection pump timing belt problem.
    By Bambiboy in forum The Commercial Range
    Last Post: 28-05-2009, 02:21 PM
  2. Diesel Injection Pump Leak
    By AutoTDI in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-06-2007, 04:04 PM
  3. Injection Pump
    By grey in forum Chat - Anything with wheels
    Last Post: 26-05-2007, 06:58 PM
  4. 1999 Golf 1.9 TDi injection pump timing
    By mistuart in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-05-2007, 07:26 PM
  5. Drainage hole behind ecu box a4
    By abaker in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-09-2006, 11:54 AM
