Thread: Whining noise from steering when turning wheel while stationary
  1. Whining noise from steering when turning wheel while stationary
    Sep 2007
    Hi - Anyone got any ideas what could be causing quite a loud whining noise when I turn the steering wheel while stationaty or low speeds? Any help appreciated - Checked fluid etc (Audi A4 B6)
  2. Re: Whining noise from steering when turning wheel while stationary
    Jul 2009
    Belgium
    alternator polie
  3. Re: Whining noise from steering when turning wheel while stationary
    Sep 2007
    The alternator pulley one is for diesels I think....they have a clutch on the pulley that fails, mine is a 1.8T petrol so does not have this. Anyone else with similar symptoms?
  4. Re: Whining noise from steering when turning wheel while stationary
    Nov 2008
    N/A
    Yes, it'll likely be the tensioner on the alternator pulley. As you stand in front of the car with the bonnet open, look right behind the grille and slightly to the right (passenger side) - it's that belt and the tensioner (littler one lower down, in the middle).
    Common part that wears.
  5. Re: Whining noise from steering when turning wheel while stationary
    Sep 2007
    Hi Thanks but what's that got to do with a noise when I turn the steering wheel? You were refering to the tensioner for the auxillary drive belt yes?
  6. Re: Whining noise from steering when turning wheel while stationary
    Nov 2008
    N/A
    It drives the power steering, so there's extra load on it at full lock.
  1. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  2. Question Wheel bearing noise not a Wheel bearing
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2009, 10:31 PM
  3. Please Help NS Front Humming noise
    Last Post: 25-06-2009, 10:42 PM
  4. Question Squeeking when turning the steering wheel
    By maxtothemax in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-05-2009, 04:24 PM
  5. Power Steering Pump Noise AC makes it worse..
    By Sparky3.0Q in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-05-2007, 09:41 AM
