Thread: A few torque settings
  1. A few torque settings
    Jun 2008
    South West U.K.
    Hello I have a 54 plate Passat 1.9 tdi Highline , and i need to change the cv boot this weekend .
    Does anyone know the torque settings for the big 27mm bolt at the end of the hub, and the 7mm hex bolts that hold the brake calipers on (just in case i need to remove them ..)
    Many thanks ..
  2. Re: A few torque settings
    Norfolk
    Drive shaft bolt. (Use new bolt) M14...115Nm plus 180 degrees.
    M16....190Nm plus 180 degrees.
    Boot bolts...M8 40Nm, M10 77Nm
  3. Re: A few torque settings
    Jun 2008
    South West U.K.
    Thanks , do you have any idea on the 7mm hex caliper bolts ?
  4. Re: A few torque settings
    Norfolk
    25Nm
  5. Re: A few torque settings
    Jun 2008
    South West U.K.
    Well the replacemant cv boot kit turned up today and that also a 27mm bolt ..
    So i gather i need to find the torques for this as it a bolt than the M14 or M16
  6. Re: A few torque settings
    Norfolk
    Torque settings refer to thread size, not bolt head size. So M14 bolt will be 14mm across the diameter of the threaded bit.
  7. Re: A few torque settings
    Jun 2008
    South West U.K.
    Thanks i understand now , it's an M14 then , thanks again
  1. 2001 A3 cylinder head bolt torque settings
    By arcangels in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-12-2009, 12:38 AM
  2. Question Clutch bolt torque settings on a Mk 3 Golf Td
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-10-2009, 10:30 AM
  3. Question B6 Passat 2006 torque wrench settings
    By freebird69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-08-2009, 09:12 PM
  4. Mk3 Golf - Front Wheel Bearing Hub Torque Settings
    By BugBit in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2008, 01:32 PM
  5. torque settings
    By jimbob in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-07-2007, 06:23 PM
