Thread: 1.9 TDi 110 Lack of power and boost.
Results 1 to 10 of 12
  1. 1.9 TDi 110 Lack of power and boost.
    Jun 2008
    My 1998 110 TDi Passat has done 140k and for the past year it has a fault which is annoying to say the least.
    When the car is driven hard up a hill and is revved over 3,000rpm it looses power and the turbo seems to cut out. The only way this can be rectified is by switching the engine off then back on again.
    I had the Air Flow Meter replaced but this hasn't solved the problem. This problem does come and go though and for a week it can be fine, however, it uses a lot more fuel when it is playing up.
    I have looked around and come to the following diagnosis that it is either the Boost Pressure Sensor or the Variable Vane Actuator. A computer is being put on the car later this week to test for fault codes but I dont think it will come up with anything.
    I was wondering if anyone on here had some ideas?
    Joe.
  2. Re: 1.9 TDi 110 Lack of power and boost.
    Norfolk
    The code read will probably be 17965 Boost pressure too high. This fault is usually due to the turbo vanes sticking. It could be boost too low, but that seems to happen less often.
  3. Re: 1.9 TDi 110 Lack of power and boost.
    I too have this issue, and after i popped my vagcom cherry last night i got the same code. It came with:
    Charge pressure control: positive deviation P1557 35 10 intermittent
    Any help?
    If it is the vanes, does this mean its new turbo time?
    Thanks in advance
    Tom
    EDIT: I've a PD engined 115bhp sport - after searching i see it could be the vanes, and if i stump up the 99$ to register my version i could get them to clean themselves - is that right?
  4. Re: 1.9 TDi 110 Lack of power and boost.
    Norfolk
    A very long hot run will sometimes sort this out. Best option, if it is sticking turbo vanes, is take turbo off and clean it. Sounds hard but it is mostly a nuts & bolts job.
  5. Re: 1.9 TDi 110 Lack of power and boost.
    Hi Martin,
    Cheers for your reply.
    I'll take the cover off later and have a good look at the turbo - i can take the opportunity to cover the glow plugs with dw40 while i am there as they're coming out at the weekend if the weather is kind.
    Vanes - I would assume these must be part of the turbine - do they replace the fixed wheel?
    Tom
  6. Re: 1.9 TDi 110 Lack of power and boost.
    Mar 2008
    Just Cumbria now.
    http://www.autozine.org/technical_sc...h_engine_3.htm
    Scroll down to
    Variable Turbine Geometry (VTG)
    Nothing to see here, move along..
  7. Re: 1.9 TDi 110 Lack of power and boost.
    Aug 2007
    My 1998 110 passat used to do exactly the same thing when my aftermarket adjustable power chip was turned up too high, when I adjusted the power down slightly, the problem never re-occurred.
  8. Re: 1.9 TDi 110 Lack of power and boost.
    Quote Originally Posted by Hex69 View Post
    Scroll down to
    Cheers, that explained it well.
    So cleaning it - shall i trust the 'power of fairy'?
    Tom
  9. Re: 1.9 TDi 110 Lack of power and boost.
    Southern County Softy
    20 Post(s)
    A4 2.5 tdi QS (mapped)
  10. Re: 1.9 TDi 110 Lack of power and boost.
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by grover View Post
    Tom
    I think you need something a touch stronger (and I don't mean alcohol, well you might by the end, but that's for you not the car )
    I've heard mention of a product called innotec recommended.
    https://www.vwaudiforum.co.uk/forum/s...hlight=innotec
  1. 1.9 TDI 110 Running rich and power loss
    By joe406 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2009, 05:46 PM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. Audi covers new ground with 2010 q7 suv
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
