Thread: Needle Lift Sensor?
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Needle Lift Sensor?
    Dec 2009
    Birmingham UK
    I had my 2001 Allroad 2.5 TDI serviced recently at a good independent and all was well except a recurring fault code - needle lift sensor (G80). I believe this relates to the fuel injection system and controls fuelling (?) I'm told it needs replacing and the part is £260 plus 2.5 hours labour.
    The car runs really well, plenty of grunt and starts without a problem and I'm averaging around 32mpg according to the trip computer. My question is really what does this sensor do and am I risking a big problem by not fixing it?
    Also does that sound like a realistic/sensible price for repair?
  2. Re: Needle Lift Sensor?
    Feb 2007
    I had the same problem but managed to get a genuine audi sensor off ebay for £35.
    It's acts like a tdc sensor and possible symptoms could be poorer starting and/or reduced economy.But like you say yours appears to be returning average mpg.
    When the sensor fails the ecu reverts to back up values.
    I only changed mine because i was having problems starting the car on occasion.
    Regards
    djl
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  3. Re: Needle Lift Sensor?
    Dec 2009
    Birmingham UK
    Thanks for reply. Car still seems to be running fine but then again I have no comparison with the sensor working properly. I suppose it could be intermittent. No point in spending £400 if i don't need to.
  4. Re: Needle Lift Sensor?
    Jan 2011
    mongleford
    The resistance output of the sensor is 100 ohms, find the connector on the engine bulkhead and fit a 100 ohm resistor into the plug which runs into the loom. I did it on mine and now it runs perfectly + no error codes anymore
  5. Re: Needle Lift Sensor?
    Jun 2011
    Rochdale
    Im having the same problem, please can you help explain how you went about fitting the resistor & where it was purchased from, thanks
  6. Re: Needle Lift Sensor?
    Dec 2009
    Birmingham UK
    I never repaired it in the end as I couldn't really justify the expense. It's not really caused me a problem - car starts and runs really well. It was an intermittent fault but I haven't had a diagnostic done for a while. Service due in 1000 miles so maybe it'll crop up again.
  7. Re: Needle Lift Sensor?
    Jun 2011
    Rochdale
    Thanks for the quick reply, like your car mine is running fine too, so I bay leave it I guess
  8. Re: Needle Lift Sensor?
    Jun 2007
    A resistor may resolve the fault code but it does not provide the fueling and optimal injection timing signal for the engine. Regards Peter
  9. Re: Needle Lift Sensor?
    Jun 2011
    Rochdale
    Engine code
    *Wauzzz4b*
    3m016788
    4b2oyc
    You can reply to my email please thank you
  10. Re: Needle Lift Sensor?
    Jun 2011
    Rochdale
    Wauzzz4b*
    3m016788
    4b2oyc
    Sorry not sure why the asterix above
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. Replies: 3
    Last Post: 26-10-2009, 11:51 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
