Thread: MK4 Central locking & window problem (rear passenger door)
  1. MK4 Central locking & window problem (rear passenger door)
    Jan 2010
    Wrexham UK
    Hi Guys, I've searched the Forums for this but can't find an exact match. I have turn key central locking and the Driver side rear door does not unlock/lock. I also have a problem with the electric window on this door as it does not operate at all.
    I suspect the problems are linked but also suspect the problem is not in the door itself (famous last words). So before I start to take apart the car can I ask if any fellow sufferers can help with suggestions on what I should check/do first.
    Many thanks.
  2. Re: MK4 Central locking & window problem (rear passenger door)
    Chester-le-Street, United Kingdom
    Quote Originally Posted by Green MKIV View Post
    Many thanks.
    in my eyes the fault lies with the wiring to the door(in the hinge area)
    or a faulty door lock/solenoid thingy,and a seperate fault with window motor.
    it's in the door,but like the weather forcasters,i've covered everything
    it may,or, may not be
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: MK4 Central locking & window problem (rear passenger door)
    As stewy says check the wiring between the B pillar and the door,otherwise you will need a fault code read to see if you can communicate with the door module
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  2. How To Open 03 Passat passenger door
    By Roy B in forum New Member Introductions
    Last Post: 05-11-2009, 02:59 AM
  3. MK4 Central Locking Problem
    By nickelly in forum Golf MK4 - 1999 - 2004
    Last Post: 06-05-2008, 08:28 AM
  4. Central door locking problem! Boot wont open! Please help!!!
    By MiniMadTez in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-08-2007, 10:19 PM
  5. Central locking only works on passenger door
    By passatv5dub in forum Passat - Archive Topics
    Last Post: 12-06-2006, 02:21 PM
