Thread: Audi A4 TDI battery...
Results 1 to 10 of 14
  1. Audi A4 TDI battery...
    Mar 2007
    Oxfordshire
    My brake warning light regularly comes on when starting and today the car really struggled to start. I've never had to replace an Audi / VW battery before - even on a high milage 8 year old car! My current Audi is only 4 years old with 68K. Anyhow, how much for the real deal OEM part? There's one on eBay for £90(new)...
  2. Re: Audi A4 TDI battery...
    May 2007
    knee deep in clunge
    14 Post(s)
    try to charge the battery firstly before anything else.Battery failure causes, if the electrics are fine then this can be a result of poor storage practise.
    Sales pitch cars not being continually dripped charged can be fine at the time with a quick boost start but this reduces the life span.
  3. Re: Audi A4 TDI battery...
    Mar 2007
    Oxfordshire
    Sounds like good advice, thanks. The car doesn't get driven that much so that probably doesn't help.
  4. Re: Audi A4 TDI battery...
    Mar 2007
    Oxfordshire
    Well I charged the battery, went for a 4 hour drive - this morning it took a few attempts to start the car. Normal scenario is that the brake warning light comes on and the engine cuts out (when trying to start the car in the cold).
    New battery required?
  5. Re: Audi A4 TDI battery...
    Southern County Softy
    20 Post(s)
    have it checked before changing it
    A4 2.5 tdi QS (mapped)
  6. Re: Audi A4 TDI battery...
    May 2007
    knee deep in clunge
    14 Post(s)
    If the battery is ok then you need to check the pressure pump in the tank, common failure from contaminated oil clogging it up from the tandem pump leaking oil back into the fuel, further problems could lie in a failing egr flap.Neither will store a fault code.I presume you have checked for fault codes and found none.Its difficult to give a cause without cranking rpm and battery condition so these suggestions are speculation.
  7. Re: Audi A4 TDI battery...
    Mar 2007
    Oxfordshire
    Thanks A8tech - there are no fault codes. I am going to get the battery tested tomorrow. I believe the EGR valve was replaced not that long ago under warranty... My gut feeling is that it's not the battery as I've never had a battery give up on any German car less than 8 years old - but I hope it is the battery!
  8. Re: Audi A4 TDI battery...
    Mar 2007
    Oxfordshire
    Fault shown on two rear wheel speed sensors.... Glow plugs look like a possible culprit - below 5 degrees.
  9. Re: Audi A4 TDI battery...
    Mar 2007
    Oxfordshire
    So the battery is fine but it sounds like there could be a problem with the plugs. I also noticed driving home that the car seemed to be misfiring - a bit lurching. Is this going to be an expensive job, could I do it myself easily?
  10. Re: Audi A4 TDI battery...
    May 2007
    knee deep in clunge
    14 Post(s)
    Glow plugs will show a fault, I suggest you remove the fuel filter and empty into a clear container.
    If there is a large oil mixture then this will indicate the tandem pump issue and further invest required.
    Remove the lift pump from the tank to visually inspect, it could be blocked with oil.
    The lift pump supplies the fuel to the tandem pump at approx .50 bar.
    The engine will start without the assistance of the lift pump but a delay will be noticed.
    When the engine is warm the holding pressure is sufficient for first time start.
    Worth a look me thinks
  1. New Audi A4 2.0TDIe
    By onemanparty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-01-2010, 01:28 AM
  2. All-new audi a8 travels light to miami debut
    Last Post: 16-12-2009, 06:00 PM
  3. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
