Thread: vag com code p0420
Results 1 to 10 of 12
  1. vag com code p0420
    Jan 2010
    bedfordshire
    mk4 golf gti,code read p0420. What does this mean and what do i need to fix the proble. Have replaced lambda sensor as was told by rac who done the diagnostic test first.eml came on again after 2 days. not sure if it could be maf sensor or cat. Help would be much apreciated as car is really annoying me.
  2. Re: vag com code p0420
    Oct 2007
    hi there, Google the fault code, then at least youll know what the problem is!!!!
  3. Re: vag com code p0420
    2005 Post(s)
    I am guessing that this is a 150PS model with an AUM engine from around 2001 to 2004? The P code P0420 is VAG code 16804.
    16804 (P0420) Cat. Conv. System, bank 1 not effective enough 035 – 001 Sporadic fault
    Basically I suspect you left it too long running it with the engine management light on and now the catalyst is faulty and the lambda sensor behind the catalyst is picking this up. In some cases you would need a new catalyst and two new lambda sensors and genuine parts and labour would cost you around £1k. If you run it around for a few weeks the cat may clean itself up and come back to life. I also often see this when people fit cheap aftermarket Chinese Air Mass Meters bought “ont tinterweb”, I had to change one of these on an Golf 4 Anniversary (almost identical to an AUM model) this week for exactly this reason, hopefully his cat will recover but at the moment it stinks so much it smell like some with a bad flatulence issue.
  4. Re: vag com code p0420
    Jan 2010
    bedfordshire
    I have replaced the cat,both sensors,maf and air filter all from vw and the light still comes on reading the same fault code.Really stuck for what to do now
  5. Re: vag com code p0420
    2005 Post(s)
    Is it an AUM engine?
  6. Re: vag com code p0420
    Jan 2010
    bedfordshire
    What is aum,sorry im female,know how to drive a car thats it lol. It's a 2001 y reg 2.0l petrol gti if that helps
  7. Re: vag com code p0420
    Jan 2010
    bedfordshire
    It is not an aum engine,it's 115bhp gti
  8. Re: vag com code p0420
    2005 Post(s)
    Look in the service book for the “motor code”, it will be AQY or APK.
  9. Re: vag com code p0420
    Jan 2010
    bedfordshire
    it is aqy
  10. Re: vag com code p0420
    Southampton, UK.
    Bit of a side track, but this is a useful wiki page, which details engine codes and more for the Mk4.
    http://en.wikipedia.org/wiki/Volkswa...d_Golf_Variant
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 2.0 TDI ultra 190
  1. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  2. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  3. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  4. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  5. 1.8T Not starting. VAG code ?
    By muddy in forum Archive posts
    Last Post: 23-03-2007, 01:01 AM
