Thread: Sharan rear wiper
  1. Sharan rear wiper
    May 2008
    sharan rear wiper just stopped working............it's getting a feed-any common faults that i should look for or will it be goosed?
    thanks
  2. Re: Sharan rear wiper
    May 2008
    wirral
    check the tail gate where your wires are fed into the body of car for any minor breaks in the wire its very easy to stretch on opening...also does the washer work if not may be the wiper stalk on steering wheel...just a though...
  3. Re: Sharan rear wiper
    May 2008
    Fixed!......looked like the wiper had been frozen to the screen and when 'operated' , the worm gear had driven the motor commutator backwards out of contact with the brushes!
  4. Re: Sharan rear wiper
    Sep 2008
    Hi David and drodders
    I have logged onto the website to try to get some assistance with my Sharan rear wiper.
    It doesn't work, however will sometimes work when I lift the tailgate, so think there must be some loose wires / connection somewhere.
    Had a look but cannot see how to get to the wires to check it out. Could either of you guys give me some idea please.
    Much appreciated.
    Gary, Wareham
  5. Re: Sharan rear wiper
    May 2008
    wirral
    when you lift your tail gate in the top corner there is a rubber sleeve between the hatch & the body pull that back theres your wires.sounds like there may be a brake somewhere...
  1. Boot Wont Open& Rear Wiper wont work...HelPPP
    By mohammedpatel in forum Golf MK5 - 2004 - 2009
    Last Post: 17-09-2009, 05:54 PM
  2. Rear wiper on '96 Sharan fuse location
    By schiffcb in forum Touran - Sharan - Caravelle
    Last Post: 25-05-2009, 11:30 AM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. rear wiper wont switch off
    By Almac1903 in forum Passat - Archive Topics
    Last Post: 25-01-2008, 09:10 PM
  5. How does the Quattro system work?
