Thread: Headlight Bulb Replacement
Results 1 to 9 of 9
  1. Headlight Bulb Replacement
    Mar 2009
    I have had a good look on this forum and can't seem to find a answer to the question of how do you change the main bulbs on a B7 and how hard is it. Some people say you need to remove the bumper but others say that it is even easier than replacing them on a B6 (4 Hex screws and you can take the unit out completely. I would appreciate any advice as my driver's side bulb went this morning. I am going to replace both of them with the recommended Philips X-treme Power H7 bulbs.
  2. Re: Headlight Bulb Replacement
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Well if it is even easier than the B6,you could be bang on ,just 3/4 torx and unit out ...5 minutes on my B6
    Stuart
  3. Re: Headlight Bulb Replacement
    Dec 2007
    b6 is easy
    b7 bumper off to get headlight out
    but to change the bulb its prety easy dont remove bumper
    just struggle a bit and get ready for the scrapes
    took me an hour to do both sides when i fitted my HIDS
  4. Re: Headlight Bulb Replacement
    Apr 2009
    n.ireland
    I just changed mine last week,took 15mins max,
    its all in the owners manual.the most work you do
    is remove the clip on covers on the back of the
    headlights........no tools needed.
    oh and I was fitting the philips x-treme bulbs too
  5. Re: Headlight Bulb Replacement
    middlewich uk
    Same as above just a bit of a squeeze and a few little cuts after but well worth it, philips extreme = great bulbs but while your there get rid of the yellow sidelight bulbs and get some white/blue ones, look much better
  6. Re: Headlight Bulb Replacement
    Jan 2010
    Leicester England
    My tip would be to make a note of the orientation of the connector that the bulb is connected to before taking them out.
    A6 3.0 SE Quattro
  7. Re: Headlight Bulb Replacement
    Mar 2009
    Quote Originally Posted by winnie070383 View Post
    Do you have any recommendations for which sidelight bulbs to get as this seems like a good idea.
  8. Re: Headlight Bulb Replacement
    middlewich uk
    I used these http://cgi.ebay.co.uk/PIAA-H-284-PLA...item1c0e3cbeae
    they have lasted a long time and are now in my second car, have read to much about the cheaper ones flaking and LED's being a proplem making the car think a bulbs blown
  9. Re: Headlight Bulb Replacement
    HowieT Guest
    OK, side lights...
    LED CANBUS 501 (error free)
    http://www.autotronicsuk.com/lightin...irs-p-573.html
    The cheapest I have found and no size issue of being slightly bigger, I have HIDs so not that bothered about lots of LEDs like others.
    HowieT
  1. headlight bulb replacement
    By Bloobat in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-09-2009, 05:27 PM
  2. Headlight bulb replacement
    By alistairvw71 in forum Touran - Sharan - Caravelle
    Last Post: 01-07-2009, 05:13 PM
  3. HEADLIGHT PROBLEMS!! - one works, one does not.. HID's
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2009, 12:54 PM
  4. Question Intermittent DIS warning of headlight bulb failure - replacement reccomendations welcome!
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2009, 06:20 PM
  5. Passat 2006 Headlight Bulb Replacement
    By Jaspercat3 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-11-2008, 09:39 PM
