Thread: Passenger Door panel Removal
Results 1 to 10 of 11
  1. Re: Passenger Door panel Removal
    Norfolk
    If you have window winder, take that off.
    Door pull handle has front plastic cover, pry that off and undo two bolts behond.
    Remove screw near bottom. Use thin spatular or trim tool to prise trim from door along bottom. Once it all feels loose, push up off window rail. Disconnect any wires and handle cable. Lift away. You will be faced with a big metal sheet bolted to the door. AAAGH !
  2. Re: Passenger Door panel Removal
    Apr 2007
    France
    12 Post(s)
    Before you start dismantling things, have you had a look here?
    https://www.vwaudiforum.co.uk/forum//...ad.php?t=89187
    post #9 worth a try.
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacré | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  3. Re: Passenger Door panel Removal
    Oct 2009
    lincs, UK
    Have tried both internal and external latches at the same time but to no avail. altho i only tried a couple of times, so will try again with more persistance. Thanks for the further info - will keep the thread going with my findings.
  4. Re: Passenger Door panel Removal
    Mar 2009
    York
    just out of interest, are all wires like speaker wires etc.. located in front of the metal sheet? Thanks!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  5. Re: Passenger Door panel Removal
    Norfolk
    All the wires enter the door from the "A" post and so originate from within the door behind the metal sheet. They then come out to the switches, speaker etc. The electronic locking and window electrics are behind the sheet with their wiring.
  1. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  2. How To Open Passenger Door on 03 Passat
    By Roy B in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2009, 12:29 PM
  3. Replies: 3
    Last Post: 06-08-2009, 04:30 PM
  4. Passenger door panel removal HELP !
    By Audi_130 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2009, 09:21 AM
  5. Passenger Door Electric Window Help
    By wacovi in forum Golf MK3 - 1993 - 1999
    Last Post: 11-05-2008, 07:51 AM
