Thread: Dension problem
Results 1 to 10 of 16
  1. Dension problem
    May 2009
    United Kingdom
    All,
    I reported a problem to Dension that when selecting by album, compilations appear multiple times because they have different artists. Dension claim this to be 'normal' - what do you guys think?
    Do you think that an album list really should be that? Should it really be dividing albums where an album has multiple artists? Or still treated a single album?
    Disappointing response, up until now very impressed with the GW500.
  2. Re: Dension problem
    Dec 2007
    Bedford
    Quote Originally Posted by rharris View Post
    All,
    I have a gateway 100 and don't have this issue.
    On iTunes try adding an "Album Artist" to the compilation (NOT ARTIST keep that what it should be)... For example if you have Now 70 put that as the album artist.
    2017 Audi A5 (B9) Coupe 2.0 TDI S-Line Quattro S Tronic
  3. Re: Dension problem
    Mansfield, UK
    That sounds perfectly normal to me, it's more about how the albums have been tagged than a problem with the Dension unit.
  4. Re: Dension problem
    May 2009
    United Kingdom
    How do you figure that normal? If you have a compilation album where every track is by a different artist, the album appears that many times in the list!
  5. Re: Dension problem
    May 2009
    United Kingdom
    Quote Originally Posted by sooty2k View Post
    Doesn't this mean you can't browse by artist properly then? This is when using the USB storage and not an iPod.
  6. Re: Dension problem
    May 2009
    United Kingdom
    Ah; okay from a bit of reading about the album artist field this could be it - none of mine are set in itunes. I'll try setting those and see what happens.. thanks guys
  7. Re: Dension problem
    Dec 2007
    Bedford
    I think this is more like an iTunes / iPod issue rather than the way the Dension works
  8. Re: Dension problem
    May 2009
    United Kingdom
    I've just gone through and applied album artist to all the problem albums and will be trying it out today. I still think an album criteria should only be using the album id3 tag and ignoring the others (that is the approach I did in an app I created for generating genre based playlists for the dension )
    Richard
  9. Re: Dension problem
    May 2009
    United Kingdom
    Still didn't work as expected.
    With the album Curtain Call, 14 of the tracks are by Eminem, 1 is by Eminem and Dr. DRE and the last one is Eminem and Nate Dogg. The album name is the same for all, and the album artist is set to Eminem for all the tracks - yet it still appears as multiple albums on the Dension (to reiterate, this is when using a USB memory stick and not an iPod)
  10. Re: Dension problem
    Dec 2007
    Bedford
    Yep you'r right this is quite normal mine does this too... other iPod devices will do the same as it's an Apple thing.
    Only think I can suggest is chaging the artist again... IE instead of having Eminem feat Dr Dre just change it to Eminem? I know I would not take this route myself. Threre must be a way you can do it in iTunes, prehaps with using commas in the Artist field... My mate is a iTunes wizz I'll ask him next time I see him and see if he knows.
  1. Crasher can you help? mk3 TDi problem
    By chackday in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 08:50 PM
  2. Power problem turbo not working
    By marfitzd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2008, 11:04 AM
  3. Advice about poss recurring problem
    By chicka in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 05:58 PM
  4. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
