Thread: A4 1.9tdi estate 130 bhp problem
  1. Question A4 1.9tdi estate 130 bhp problem
    Oct 2009
    bedworth england
    Hello all,I have a lovely A4 53 reg tdi estate with an annoying light problem.The car drives superb for around 4-5 weeks then i get the traction control light staying on and the coil light flashing.If i leave the car overnight then all is good again in the morning.While the lights are on it goes into "limp" mode.It has been onto the diagnostics and i was told it was the throttle position sensor which i have had changed.It has also had the wiring to the ECU checked and all is good.I drive back and forth to work and i am not a quick driver so have been told it might need a good drive to blow any crap away.Does anyone have any ideas as if it is the ECU then i cannot afford to get it done but surely a car of this age would not need one of them......................field8@hotmail.co.uk
  2. Re: A4 1.9tdi estate 130 bhp problem
    Jan 2009
    towcester northants
    double check the wiring on the throttle pedal
    last one i had do this was a bad connection/water in the connector
    get the throttle checked on vag com before and after
  3. Re: A4 1.9tdi estate 130 bhp problem
    Oct 2009
    bedworth england
    Quote Originally Posted by towcestervag View Post
    Hello and thanks for the reply,my car was at a company for the day who checked all the wiring and came back with no problem.I aggree that it seems like an electrical fault as it happens every 3-5 weeks then all is fine.Thanks again.
  1. Question A4 1.9TDI Multitronic Problem
    By mdurna in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-06-2013, 08:31 AM
  2. Replies: 1
    Last Post: 17-12-2007, 01:02 AM
  3. 2003 A4 1.9tdi tappet problem
    By thomas spain in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-06-2007, 05:57 PM
  4. audi a4 1996 tdi 1.9tdi brake problem
    By hookc2003 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2006, 10:53 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
