Thread: Coming Home Lights
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. Re: Coming Home Lights
    #21
    Dec 2007
    Bedford
    Quote Originally Posted by Clint1093 View Post
    I maybe missing the plot but am I right in saying that my A4 B7 2.0 TDI SE which does not have coming home lights as standard can be adjusted via a code to have these lights?
    Quote Originally Posted by grr View Post
    So the conclusion here is that either way if you have the button or not, you need to have auto lights (with rain sensor etc.) to be able to add the coming home lights?
    YES that is right... It does not matter if you don't have the button... As long as your lights are automatic and turn on by themselves then yes you can enable coming home lights.
    2017 Audi A5 (B9) Coupe 2.0 TDI S-Line Quattro S Tronic
  2. Re: Coming Home Lights
    #22
    Aug 2009
    Norway
    And there's no other option that can enable the needed module for this? Like bending bi-xenon? I have that, but unfortunately I don't have auto lights...
    Audi B7 A4 Avant 2.0TFSIQ aut (241hp, sports susp., valc. leath. sports seats, MF sports steer, navi plus, BOSE, BT, PDC, dyn. bi-xenon, 18" MOMO GT-R)
    BMW 118d (185hp, alu trim, sports int, rain s., navi, MF steer., BT, PDC, 17" M, dual clim., M aerodyn)
    Volvo XC90 (bull bar, side steps, widebody/wheel arch., dual AC, MF steer, 7S, el. leather seats, navi, rain s., phone, prem. aud., bi-xen.+xen. driv. lamps, Webasto, PDC)
  3. Re: Coming Home Lights
    #23
    May 2007
    knee deep in clunge
    14 Post(s)
    no you can retro fit by taking the switched delayed earth from the interior light and converting via a relay to output to live to the front fog circuit
    the only down side is the fogs will come on when you remove the ignition key as thew interior lights do
    just done my own test loom today consisting of 2 5 pin relays and some wire
  4. Re: Coming Home Lights
    #24
    Jan 2012
    Livingston, Scotland
    Hi all,
    I'm new to the forum and as a new A4 owner am keen to see what I can change on the car for the better. Can this mod be done without the auto lights or do you need them for this to work?
    Simon
  5. Re: Coming Home Lights
    #25
    Jul 2008
    Uranus
    Yes, as A8 tech has mentioned in the post above yours...
    Mar 2010
    bangor uk
    Maybe someone could produce a kit to retrofit this similar(or even the same) as a8tech has. I think there would be a lot of interest from forum members for them! What you reckon?????
    Feb 2010
    staffordshire
    A8 has already done a a wiring diagram in my other thread, this is for anyone with low line cars. I'm in the process of doing the same mod for cars fitted with a high line module. Read here
    https://www.vwaudiforum.co.uk/forum/s...d.php?t=125648
    Full vcds HEX-USB-CAN Interface available in the staffordshire area PM me
  8. Re: Coming Home Lights
    #28
    May 2007
    knee deep in clunge
    14 Post(s)
    b6/b7 lowline mod fogs on with unlock command from remote fob and ignition key removal
    ScreenShot004 by a8 tech, on Flickr
  9. Re: Coming Home Lights
    #29
    Jul 2012
    West Midlands
    I've just had my 2009 A3 programmened for Scandinavian mode so the back lights come on with the DRL and they don't go dim, what is involved setting up the come home lights properly as I don't have a switch for it?
  1. Coming Home Lights ?
    By Arthercrow in forum Passat CC
    Last Post: 15-01-2010, 06:06 PM
  2. Hazard lights coming on when indicating
    By Dex2034 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-09-2008, 02:26 PM
  3. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  4. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
  5. Engine cut outs, warning lights coming on!
    By barnaby82 in forum Archive posts
    Last Post: 04-02-2008, 07:59 PM
